Hi all,
I’m using Wasabi for backups of my Wordpress sites and this worked like a charm for a while. But when I checked yesterday it turns out the backups weren’t made for the last 20 days…
I also have local backups set up to be safe, but these are not working as well! The folders are created, but remain empty. Logs say the backup completed…
What I found so far:
The log folder /home/cyberpanel is spammed with [random-number] files. The content of these files is “Completed.[200]”
/home/cyberpanel/incbackuplogs only contains 1623 lines of:
Starting Incremental Backup job…
Manually starting the cron takes a while, but no backups are created. " /usr/local/CyberCP/bin/python /usr/local/CyberCP/IncBackups/IncScheduler.py ‘6 Hours’"
Deleting all the websites from the backup config and adding only one does nothing as well.
Creating a new key /bucket on Wasabi, config a new backup in cyberpanel and manually starting with the cron does nothing as well.
How can I further debug this issue?
Thanks!
Where do I start to debug this? There are no errors and no backups
