I just tried opening CyberPanel Terminal hours ago but it did not work … ERROR : Connection Established, Connection Closed … Nothing could be done … Do i need to enable Password Login to run CyberPanel Terminal ?? Or is anything else blocking the CyberPanel Terminal ??
i dont know, never try
but perhaps it will run…
Well, it doesn’t seem to work since Password Login is disabled and CyberPanel authentication into SSH would need a username and password, I don’t even know the CyberPanel Terminal username … I would want to know if disabling SSH Password Login really prevents CyberPanel Terminal from working, I don’t want to enable Password Login for security reasons …
For cyberpanel terminal you should have a valid SSL for hostname and root ssh needed
Root SSH —> Is it root login ?? Please i disabled that …
I’ve spent 2 hours now trying to get SSH to connect through PUTTY but i get Fatal Error: Connection timed out … I tried rebooting server and others, still nothing has worked
