Reverse Proxy to docker container with encoded slash
Hello everyone,
I am currently working on setting up a reverse proxy that directs traffic to a Docker container, and I’ve hit a bit of a snag.
My application requires that certain URLs containing encoded slashes (%2F) be passed to the Docker container without being decoded or altered.
For example, if a user accesses https://example.com/api/v1/data/a%2Fb, I need the reverse proxy to forward the request exactly as https://example.com/api/v1/data/a%2Fb (with %2F intact), instead of decoding it to https://example.com/api/v1/data/a/b.
In Apache there is ‘AllowEncodedSlashes NoDecode’ but i cant find anything similar or a workaround for openlightspeed.
Has anyone faced a similar issue or knows a way to configure the reverse proxy to forward the URL without decoding the slashes? Any guidance or examples of configuration files would be greatly appreciated!
Thanks in advance!
You can use the guidelines in this topic, with these configurations I can use Cyberpanel as a reverse proxy adjusting with yoursite.com.
nano /usr/local/lsws/conf/httpd_config.conf
In some cases address it is necessary to indicate the full path with https://.
note line 496 - 498 and 499
496 home path redirect
498 full path with https
499 commented if you have the ip with the port
