hi
I use hostinger default centos 7.9 with default cyberpanel installed
and I successfully backup my website ,
but when I retore it
the folder have come back but no database
and I check the error log
there is
[07.18.2022_13-09-58] Backup version 2.1.1+ detected…
[07.18.2022_13-09-58] Could not restore MYSQL database: WJnELxdsHdq1f! [restoreDatabaseBackup]
[07.18.2022_13-09-58] Failed to restore database WJnELxdsHdq1f. But it can be false positive, moving on…
[07.18.2022_13-09-58] (1396, “Operation CREATE USER failed for ‘WJnELxdsHdq1f’@‘localhost’”)[createDatabase]
Hi, yes you are right , I have change root mysql password, so the three file have one password
usr/local/CyberCP/CyberCP/settings.py
/home/cyberpanel/.my.cnf
/etc/cyberpanel/
but , ~/.my.conf have a different password.
so , I change .my.conf the same passoword as
/etc/cyberpanel/
