Hi, is it possible to modify/remove these links?
Thx for info
Thx for info
You can edit the base html file
https://github.com/usmannasir/cyberpanel/blob/1.8.0/baseTemplate/templates/baseTemplate/index.html
/usr/local/CyberCP/baseTemplate/templates/baseTemplate/index.html
Also read → Manage Services - 08 - Server - CyberPanel Community
Sorry if I was not clear enough. I want to disable these urls completely, so if “someone” tries to reach mydomain.com:8090/rainloop or phpmyadmin, I dont wanna lead em to corresponding pages. Just curiouse, where these “redirects” are defined.
Ok, so i can “remove” or “rename” the these folders in CyberCP public folder. Is this access rule for public folder hardcoded, if accessing cp over port 8090?
Yes you can remove these folders, there won’t be any issue.
