Remote Destinations Backup - 2.0.3
I recently updated the version of Cyberpanel to 2.0.3 and found a possible bug in the system of remote destinations for Backup, simply the destinations previously registered before disappeared, I tried to add and presented an error of execution of the command.
Host IP-SERVER not found in /root/.ssh/known_hosts
End Of File (EOF). Exception style platform.
command: /bin/ssh
args: [’/bin/ssh’, ‘-o’, ‘StrictHostKeyChecking=no’, ‘-p’, ‘PORT-SERVER’, ‘root@IP-SERVER’, ‘mkdir ~/.ssh || rm -f ~/.ssh/temp && rm -f ~/.ssh/authorized_temp && cp ~/.ssh/authorized_keys ~/.ssh/temp || chmod 700 ~/.ssh || chmod g-w ~’]
buffer (last 100 chars): b’’
before (last 100 chars): b’mkdir: \xc3\xa9 imposs\xc3\xadvel criar o diret\xc3\xb3rio \xe2\x80\x9c/root/.ssh\xe2\x80\x9d: Arquivo existe\r
after:
match: None
match_index: None
exitstatus: None
flag_eof: True
pid: 123392
child_fd: 8
closed: False
timeout: 3
delimiter:
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
searchwindowsize: None
delaybeforesend: 0.05
delayafterclose: 0.1
delayafterterminate: 0.1
searcher: searcher_re:
0: re.compile(b’password:’)
1: re.compile(b’Password:’)
2: re.compile(b’Permission denied’)
Would anyone know if this is really a bug and if it is known how to solve it?
Any news on this?
Current version is 2.3.2
Try updating to this version and see if that solves the issues.
Did that in almalinux, still the same error.
I have same problem. I have tried SFTP to two or three different locations and same error.
I got my borg backup using SFTP also and it can connect just fine.
My error:
Host *************.your-storagebox.de found: line 7
/root/.ssh/known_hosts updated.
Original contents retained as /root/.ssh/known_hosts.old
command: /usr/bin/ssh
args: [‘/usr/bin/ssh’, ‘-o’, ‘StrictHostKeyChecking=no’, ‘-p’, ‘22’, ‘@.your-storagebox.de’, ‘mkdir ~/.ssh || rm -f ~/.ssh/temp && rm -f ~/.ssh/authorized_temp && cp ~/.ssh/authorized_keys ~/.ssh/temp || chmod 700 ~/.ssh || chmod g-w ~’]
before (last 100 chars): b"‘*************.your-storagebox.de’ (RSA) to the list of known hosts.\r\r\nexec request failed on channel 0\r\r\n"
after:
match: None
match_index: None
exitstatus: 255
flag_eof: True
pid: 593231
child_fd: 5
closed: False
timeout: 3
delimiter:
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
0: re.compile(b’password:‘)
3: re.compile(b’File exists’) [setupSSHKeys]
