Remote backup issue: Error message: 'transferStatus'
Tearing my hair out on this one. Upgrading Ubuntu version so created new servers. Using Remote Backups feature, it just fails with error:
Can not initiate remote transfer. Error message: ‘transferStatus’
There is nothing in the logs on either server.
Both servers are at latest cyberpanel version and fully up to date.
Firewall is enabled on 22 and 8090 on source server (if not it fails to connect)
API access is enabled on both servers.
The error message and logging on this issue is completely useless which doesn’t help.
Anyone have any ideas how to fix this?
Thanks
im also trying to find the answer but im afraid the answer is no solution or it works no more. and l can make sure admins dont care about it.
Thanks, it is strange as one server worked and the other did not. I guess I will do a manual backup, copy the backup over and restore.
Yeah I’m doing the same thing right now.
Make sure all the file permissions are done correctly.
Because After restore all the permissions are gone.
