Hello folks,
I want to migrate my websites from an old cyberpanel server to a new one. So when i use the “remote backup” on the new server I’m able to fetch the accounts from the old server and start the transfer.
The logs says everything is fine but the data of the websites simply does not transfer and it does not add a new website on the new server.
Log:
Starting remote Backup
Start date: 11.02.2021_21-53-32
[11.02.2021_21-53-32] Currently generating local backups for: xxxx.com
[11.02.2021_21-53-32] Starting local backup for: xxxx.com
[11.02.2021_21-53-34] Waiting for backup to complete…
[11.02.2021_21-54-00] Backup Completed for: xxxx.com
[11.02.2021_21-54-00] Local Backup Completed for: xxxx.com
[11.02.2021_21-54-00] Sending /home/backup/transfer-2617/backup-xxxx.com-11.02.2021_21-53-32.tar.gz to 193.xxx.xxx.xxx.
[11.02.2021_21-54-00] Sent /home/backup/transfer-2617/backup-xxxx.com-11.02.2021_21-53-32.tar.gz to 193.xxx.xxx.xxx.
[11.02.2021_21-54-00] #############################################
[11.02.2021_21-54-00] Backups are successfully generated and received on: 193.xxx.xxx.xxx
Starting Backup Restore
Start date: 11.02.2021_21-54-02
[11.02.2021_21-54-02] Backup Restore complete
completed[success]`
Both servers are at the same version (2.1 Build 2).
Thank you in advance
Regards ![]()
