Remote Backup did not work correct
Renote backup did not work if one of the cyberpanels is behind a firewall.
I have a live server fo a customer (live1) and da development server (dev2).
live1 is hosted in the internet and dev2 inside my companys network - protected by perimeter firewall, nir reachable from outside.
I did
  1. API Access enabled on live1 and dev2
  2. set SSH Port back to 22
  3. Start “Remote Backup” on dev2
  4. Enter IP of live1 and Password of User “admin” from live1
  5. dev2 connects to live1 and pulls list of all websites
  6. I select one website and click Transfer Button
  7. on the left side i got:
Starting remote Backup
Start date: 02.02.2022_17-23-48
[02.02.2022_17-23-58] Currently generating local backups for: domain.tld
[02.02.2022_17-23-58] Starting local backup for: domain.tld
[02.02.2022_17-24-00] Waiting for backup to complete…
[02.02.2022_17-26-20] Backup Completed for: domain.tld
[02.02.2022_17-26-20] Local Backup Completed for: domain.tld
[02.02.2022_17-26-20] Sending /home/backup/transfer-6819/backup-domain.tld-02.02.2022_17-23-58.tar.gz to [ip of FIREWALL]
[02.02.2022_17-28-32] Sent /home/backup/transfer-6819/domain.tld-02.02.2022_17-23-58.tar.gz to [ip of firewall]
[02.02.2022_17-28-32] #############################################
[02.02.2022_17-28-32] Backups are successfully generated and received on: [ip of firewall]
  1. Right side shows:
Starting Backup Restore
Start date: 02.02.2022_17-28-34
[02.02.2022_17-28-34] Backup Restore complete
completed[success]
…but there is no website on dev2
So it´s clear what happened; live1 trys to SSH to dev2 and can´rt reach.
This is a BUG by design - live1 server never got the credentials or allowness to connect via ssh directly to dev2. The initial ssh tunnel from dev2 to live1 is not being used to transfer the .tar.gz file.
In my constellation my firewall blocks direct access to my dev2 computer.
Better is the solution for remote backup, tha the client (dev2) waits for a flag-file set in the /home/backup directory of live1, that backup file is ready to transfer and than pulls this file. Pushing from live1 to dev 2 is not a good idea. My 5 cent …
But ok, if you say I have to live with it:
PLEASE remove the BUG in the logs saying !“Restore Complete” and “Backups are successfully generated and received on:”
Non of these 2 steps are successfull.
Best regards,
Kai
Did you manage to solve the bug? I have the same problem here in 2024. SSH port 22. API access granted. Sites are backed up on the source server, but are not transferred to the destination server.
Hello Rafael,
I am sorry to inform you that I have not found a direct solution to the specific problem you described. Unfortunately, as you have seen, Cyberpanel Support and the community have not responded to my problem either.
The only solution I can see, which I have never tried, is to create a special rule in the firewall that passes incoming SSH requests from the external server directly to the internal server based on its IP. That should work.
At the time, I didn’t want to make any backups, I just wanted to conveniently exchange websites between an internal development server and an external live server in order to develop them further. At that time I chose the manual process and made a manual backup of the website via the Cyberpanel backend and then copied the finished backup file into the import directory /home/backup of the internal server and then imported it from there. This always works.
What you can do depends entirely on your task. If it’s just a matter of backups, you could create them locally on the server and then move them to a second server using lsyncd.
Describe your problem - maybe you can find help in the community
Thankz for you feedback
