Rebuild httpd_conf
I was upgraded my server to latest version.
But my Litespeed wont start…
● lshttpd.service - OpenLiteSpeed HTTP Server
   Loaded: loaded (/usr/lib/systemd/system/lshttpd.service; enabled; vendor preset: disabled)
   Active: activating (auto-restart) (Result: signal) since Çrş 2022-07-06 16:45:10 +03; 2s ago
  Process: 24842 ExecStart=/usr/local/lsws/bin/lswsctrl start (code=exited, status=0/SUCCESS)
 Main PID: 24878 (code=killed, signal=SEGV)
   CGroup: /system.slice/lshttpd.service
Tem 06 16:45:10 server.xx.buzz systemd[1]: Unit lshttpd.service entered failed state.
Tem 06 16:45:10 server.xx.buzz systemd[1]: lshttpd.service failed.
But when I check my httpd_conf file its showing bad configuration… I think this panel should be have rebuild httpd_config
– Unit lshttpd.service has finished shutting down.
Tem 06 16:38:48 server.xx.buzz systemd[1]: lshttpd.service holdoff time over, scheduling restart.
Tem 06 16:38:43 server.xx.buzz systemd[1]: lshttpd.service failed.
Tem 06 16:38:43 server.xx.buzz systemd[1]: Unit lshttpd.service entered failed state.
Tem 06 16:38:43 server.xx.buzz systemd[1]: lshttpd.service: main process exited, code=killed, status=11/SEGV
Tem 06 16:38:43 server.xx.buzz kernel: litespeed[22007]: segfault at 0 ip 00007f81db457f78 sp 00007fff5a209fe8 error 4 in libc-2.17.so[7f81db319000+1c4000]
Tem 06 16:38:43 server.xx.buzz systemd[1]: Started OpenLiteSpeed HTTP Server.
It’s crazy this question has been open for so long with now answer. I couldn’t find anything anywhere about rebuilding the openlitespeed configuration. Can the CyberPanel staff comment on this?
