Apr 26 21:51:45 56818 postfix/qmgr[56571]: 5043A1218B1: from=<>, size=3482, nrcpt=1 (queue active)
Apr 26 21:51:45 56818 postfix/proxymap[57115]: error: open /etc/postfix/mysql-virtual_domains.cf: Permission denied
Apr 26 21:51:45 56818 postfix/proxymap[57115]: warning: mysql:/etc/postfix/mysql-virtual_domains.cf is unavailable. open /etc/postfix/mysql-virtual_domains.cf: Permission denied
Apr 26 21:51:45 56818 postfix/trivial-rewrite[57113]: warning: virtual_mailbox_domains: proxy:mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Apr 26 21:51:45 56818 postfix/trivial-rewrite[57113]: warning: virtual_mailbox_domains lookup failure
Apr 26 21:51:45 56818 postfix/error[57116]: 5043A1218B1: to=[email protected], relay=none, delay=336515, delays=336515/0.04/0/0.01, dsn=4.3.0, status=deferred (address resolver failure)
Apr 26 22:00:46 56818 dovecot: master: Dovecot v2.3.7.2 (3c910f64b) starting up without any protocols (core dumps disabled)
Apr 26 22:00:46 56818 postfix[607]: Postfix is running with backwards-compatible default settings
Apr 26 22:00:46 56818 postfix[607]: See http://www.postfix.org/COMPATIBILITY_README.html for details
Apr 26 22:00:46 56818 postfix[607]: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
Apr 26 22:00:46 56818 opendkim[594]: OpenDKIM Filter v2.11.0 starting (args: -x /etc/opendkim.conf)
Apr 26 22:00:47 56818 postfix/postfix-script[764]: warning: symlink leaves directory: /etc/postfix/./makedefs.out
Apr 26 22:00:47 56818 postfix/postfix-script[767]: warning: symlink leaves directory: /etc/postfix/./cert.pem
Apr 26 22:00:47 56818 postfix/postfix-script[770]: warning: symlink leaves directory: /etc/postfix/./key.pem
Apr 26 22:00:47 56818 postfix/postfix-script[794]: starting the Postfix mail system
Apr 26 22:00:47 56818 postfix/master[796]: daemon started – version 3.4.13, configuration /etc/postfix
Apr 26 22:00:47 56818 postfix/qmgr[798]: 63E061218CE: from=[email protected], size=1606, nrcpt=1 (queue active)
Apr 26 22:00:47 56818 postfix/proxymap[801]: warning: connect to mysql server localhost: Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2)
Apr 26 22:00:47 56818 postfix/trivial-rewrite[800]: warning: virtual_mailbox_domains: proxy:mysql:/etc/postfix/mysql-virtual_domains.cf: table lookup problem
Apr 26 22:00:47 56818 postfix/trivial-rewrite[800]: warning: virtual_mailbox_domains lookup failure
Apr 26 22:00:48 56818 postfix/error[803]: 63E061218CE: to=[email protected], orig_to=, relay=none, delay=424409, delays=424409/0.12/0/0.03, dsn=4.3.0, status=deferred (address resolver failure)
Attach your server with cloud request for email debuger and reset email
how to do it?
