La
ClosedRainloop webmail not found
Go
Gonzalo
#2
Same issue here … don´t know what’s happening … any ideas?
Io
Iovanny
#3
tb
tbaldur
#4
It’s /snappymail and not /rainloop
Io
Iovanny
#5
i solved it by upgrading cyberpanel
source: 02 - Upgrading CyberPanel
The following command can be used to upgrade to the latest version.
If using a sudo user rather than root, try this:
sudo su - -c "sh <(curl https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh || wget -O - https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh)"
SR
Thank you so much, brother. It’s working for me also. You save my day. Thanks again @Iovanny ![]()
