Szmycu
#1
I have blank page no rainloop or snappymail on my cyberpanel
yourIP:8090/rainloop - there is Not Found
The requested resource was not found on this server.
Use yourIP:8090/snappymail - here is nothing too
/usr/local/CyberCP/public/rainloop - there is nothing in folder - blank folder
What i have to do to install this?
Run the upgrade script and then try again will be ok
orosys
#3
same issue facing, can you suggest how to upgrade script ?
Hello @orosys Happy you are here
