Hi there, had a quick question. I’ve spent a ton of time going through and configuring the many, many options available for us to tinker with in the OpenLiteSpeed panel (the one that’s available at https://hostname.dieselbaby.site:7080
by default) and as I am in the process of being about to set up a new installation of cyberpanel on a new server, I want to backup/export my current configuration and settings of OpenLiteSpeed and be able to import them into my newly setup instance of Cyberpanel.
The only thing I was able to find online after some searching was a suggestion to copy over the file at /usr/local/lsws/conf/httpd_config.xml
– is this sufficient to accomplish what I’d like to do, or would it be better to try copying over the rest of the files within that parent conf
directory?
Thanks
