CyberPanel Community
Python dependency conflicts - I can't upgrade my cyberpanel 2.3.4
mb
mblendinger #1
Hi there, I can’t upgrade cyberpanel, here the info:
Current Version 2.0
Build 0
Latest Version 2.3
Latest Build 4
OS: Centos-7
Error:
upgrade command finish with this failure
transcript:
ERROR: pip's dependency resolver does not currently take into account all the packages that are i        nstalled. This behaviour is the source of the following dependency conflicts.
certbot 0.21.1 requires acme==0.21.1, but you have acme 1.9.0 which is incompatible.
Successfully installed Babel-2.8.0 ConfigArgParse-1.2.3 Django-3.1.3 IPy-1.0 Jinja2-2.11.3 Markup        Safe-1.1.1 PyNaCl-1.4.0 acme-1.9.0 asgiref-3.3.1 asn1crypto-1.4.0 backports.ssl-match-hostname-3.        7.0.1 bcrypt-3.2.0 beautifulsoup4-4.9.3 boto3-1.18.26 botocore-1.21.26 cachetools-4.1.1 certifi-2        020.11.8 cffi-1.14.3 chardet-3.0.4 charset-normalizer-2.0.12 cloudflare-2.8.13 configobj-5.0.6 cr        yptography-3.2.1 decorator-4.4.2 docker-4.3.1 docker-pycreds-0.4.0 docutils-0.16 enum34-1.1.10 fi        lelock-3.0.12 funcsigs-1.0.2 future-0.18.2 google-api-core-1.23.0 google-api-python-client-1.12.5        google-auth-1.23.0 google-auth-httplib2-0.0.4 google-auth-oauthlib-0.4.2 googleapis-common-proto        s-1.52.0 httplib2-0.18.1 idna-2.10 ipaddress-1.0.23 jmespath-0.10.0 josepy-1.5.0 jsonlines-1.2.0        jsonpatch-1.26 jsonpointer-2.0 mock-4.0.2 mysqlclient-2.0.1 oauthlib-3.1.0 paramiko-2.7.2 parseda        tetime-2.6 pbr-5.5.1 pexpect-4.8.0 prettytable-1.0.1 protobuf-3.13.0 psutil-5.7.3 ptyprocess-0.6.        0 py3dns-3.2.1 pyOpenSSL-19.1.0 pyRFC3339-1.1 pyasn1-0.4.8 pyasn1-modules-0.2.8 pycparser-2.20 py        gpgme-0.3 pyotp-2.4.1 pysftp-0.2.9 python-dateutil-2.8.1 pytz-2020.4 pyudev-0.22.0 pyxattr-0.7.1        pyyaml-6.0 requests-2.26.0 requests-file-1.5.1 requests-oauthlib-1.3.0 requests-toolbelt-0.9.1 rs        a-4.6 s3transfer-0.5.0 setuptools-59.6.0 six-1.15.0 soupsieve-2.0.1 sqlparse-0.4.2 tldextract-3.0        .2 tornado-6.1 uritemplate-3.0.1 urllib3-1.26.5 validators-0.18.1 wcwidth-0.2.5 websocket-client-        0.57.0
--2023-05-02 11:37:18--  https://raw.githubusercontent.com/usmannasir/cyberpanel/v2.3.4/plogical/        upgrade.py
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.108.1        33, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... conne        cted.
HTTP request sent, awaiting response... 200 OK
Length: 114564 (112K) [text/plain]
Saving to: ‘upgrade.py’
100%[=======================================================>] 114,564     --.-K/s   in 0.02s
2023-05-02 11:37:18 (5.38 MB/s) - ‘upgrade.py’ saved [114564/114564]
  File "/usr/local/CyberPanel/lib/python3.6/site-packages/MySQLdb/__init__.py", line 18, in <modu        le>
    from . import _mysql
ImportError: /usr/local/CyberPanel/lib/python3.6/site-packages/MySQLdb/_mysql.cpython-36m-x86_64-        linux-gnu.so: undefined symbol: SSL_get_error
During handling of the above exception, another exception occurred:
  File "upgrade.py", line 14, in <module>
    import MySQLdb as mysql
  File "/usr/local/CyberPanel/lib/python3.6/site-packages/MySQLdb/__init__.py", line 24, in <modu        le>
    version_info, _mysql.version_info, _mysql.__file__
NameError: name '_mysql' is not defined
above command failed...
mb
mblendinger #3
thank you! not luck with this:
python3 -m pip uninstall acme
Cannot uninstall requirement acme, not installed
mb
mblendinger #5
yes:
You are using pip version 8.1.2, however version 23.1.2 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
mb
mblendinger #6
Cache entry deserialization failed, entry ignored
Collecting pip
Downloading https://files.pythonhosted.org/packages/fa/ee/74ff76da0ab649eec7581233daeb43d8aa35383d8f75317b2ab3b80c922f/pip-23.1.2.tar.gz (2.1MB)
100% |████████████████████████████████| 2.1MB 406kB/s
Complete output from command python setup.py egg_info:
File “”, line 1, in
File “/tmp/pip-build-WEvbRk/pip/setup.py”, line 7
def read(rel_path: str) → str:
SyntaxError: invalid syntax
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-WEvbRk/pip/
jo
josephgodwinke #7
Possibly the upgrade tried to change python wheels or something try within venv
python3 -m pip install -U pip
