Today i created some ftp user. And then i try to connect with Filezilla. But i can’t connect to the server.
This log from FIlezilla
Status: Resolving address of xxx.blablabla.com
Status: Connecting to xx.xx.xx.xx:21…
Status: Connection established, waiting for welcome message…
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 1 of 50 allowed.
Response: 220-Local time is now 16:31. Server port: 21.
Response: 220-IPv6 connections are also welcome on this server.
Response: 220 You will be disconnected after 15 minutes of inactivity.
Command: USER ftp_user
Response: 331 User ftp_user OK. Password required
Command: PASS *********
Response: 530 Login authentication failed
Error: Critical error: Could not connect to server
And when i login to ssh, and hit systemctl status pure-ftpd
pure-ftpd.service - Pure-FTPd FTP server
Loaded: loaded (/usr/lib/systemd/system/pure-ftpd.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2018-07-30 16:24:31 WIB; 56s ago
Process: 2850 ExecStart=/usr/sbin/pure-config.pl /etc/pure-ftpd/pure-ftpd.conf --daemonize (code=exited, status=0/SUCCESS)
Main PID: 2851 (pure-ftpd)
CGroup: /system.slice/pure-ftpd.service
├─2851 pure-ftpd (SERVER)
├─2858 pure-ftpd (IDLE)
├─2859 pure-ftpd (PRIV)
├─2870 pure-ftpd (IDLE)
└─2871 pure-ftpd (PRIV)
Jul 30 16:24:31 xxx.blablabla.com systemd[1]: Starting Pure-FTPd FTP server…
Jul 30 16:24:31 xxx.blablabla.com systemd[1]: PID file /var/run/pure-ftpd.pid not readable (yet?) after start.
Jul 30 16:24:31 xxx.blablabla.com pure-ftpd[2851]: (?@?) [DEBUG] Couldn’t load the DH parameters file /etc/ssl/private/pure-ftpd-dhparams.pem
Jul 30 16:24:31 xxx.blablabla.com systemd[1]: Started Pure-FTPd FTP server.
Jul 30 16:25:25 xxx.blablabla.com pure-ftpd[2870]: (?@xx.xx.xx.xx) [INFO] New connection from xx.xx.xx.xx
Jul 30 16:25:25 xxx.blablabla.com pure-ftpd[2870]: pam_listfile(pure-ftpd:auth): Couldn’t open /etc/ftpusers
Jul 30 16:25:25 xxx.blablabla.com pure-ftpd[2870]: pam_unix(pure-ftpd:auth): check pass; user unknown
Jul 30 16:25:25 xxx.blablabla.com pure-ftpd[2870]: pam_unix(pure-ftpd:auth): authentication failure; logname= uid=0 euid=0 tty=pure-ftpd ruser=…s rhost=
Hint: Some lines were ellipsized, use -l to show in full.
Pliss help me. Thank You
