hello
anyone know what is this ?
this is always goes to TOP Process
is that normal ? with that process come to top ?
Not much of an issue. Is it continously on top all the time?
What is the average load of your server?
right now it’s look fine…
@die2mrw007 : if you said that was server interface. then the process will on top if 8090 panel opened i guess
update:
solved: CP Web panel load it… . thank you
