Hi guys!
My problem is the following, I’m Brazilian and I’m building a system, our language (pt-br) has a lot of accents and this is bothering the performance too much, because if I put a word with accents, after I save the file it removes the letter .
Ex:
“Classificação” → after saving it looks like this → “Classificao”
apart from “ç” and “ã”, it does not occur in all words, but in most.
Edit files using FTP and Visual Studio Code (or any other editor) instead of the file manager.
It’s an issue with the file manager and not using utf-8 encoding (?).
cPanel’s (which is what most have probably used before switching to cyberpanel) file manager will show:
" Back up the original file before converting character sets, since this action can produce unexpected results." Please select the character encoding to use when opening this file:
utf-8
when opening and editing files unless disabled. Hopefully cybpanel can implement something similar in the future.
