Type your messageHello everyone!
I’m installing CyberPanel on an OVH VPS, and when I log in and make sudo su to move the user to root, and run the installation command as requested on the official website, he doesn’t identify that I’m running as root and keeps asking me to i make sudo su to install.
What can it be?
File “install.py”, line 2388, in
main()
File “install.py”, line 2342, in main
checks.installAcme()
File “install.py”, line 2197, in installAcme
preFlightsChecks.call(command, self.distro, command, command, 1, 0, os.EX_OSERR)
File “install.py”, line 207, in call
res = subprocess.call(shlex.split(command))
File “/usr/lib64/python3.6/subprocess.py”, line 287, in call
with Popen(*popenargs, **kwargs) as p:
File “/usr/lib64/python3.6/subprocess.py”, line 729, in init
restore_signals, start_new_session)
File “/usr/lib64/python3.6/subprocess.py”, line 1364, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘/root/.acme.sh/acme.sh’: ‘/root/.acme.sh/acme.sh’
Oops, something went wrong…
first sudo su, then passwd root (change password) and log in as root again.
run the setup command, you won’t get errors anymore.
The solution of the problem is explained here; OVH Lokasyon Sanal Sunuculara (VPS) Cyberpanel Kurmak
I am having struggling to access CyberPanel, the azure instance isn’t accepting the key for SSH and I don’t have a alternative password.
Default 1234567 Password isn’t working with admin username on the weblogin page.
Andy suggestions would be highly appreciated :neutral:
