platform : Latest WP
case : migration from CWP (sample.com) to CyberPanel (newname-sample.com)(only public html and sql)
File zip publichtml size : 14GB
File SQL manual export .sql : 32 MB
What i do
Extract publichtml.zip to Cyberpanel new user/domain/website (newname-sample.com)
database manual create + username and password
SQL imported via cli because of size
edit wpconfig change database info etc etc , include define URL
test open site: success
test wp-admin and login: success
test change permalink: success
test all link+add new test post: success
missing:
litecache plugin for WP
i install it manual from Wordpress repo plugin–> add new
question: #1
then… ?
what should i do for make it optimal ?
You can install it by any methods. Cyberpanel doesnt configure the plugin settings, you need to do that manually.
There is no optimal settings as each website structure is different (theme, plugin set, design, etc). What works for one website wont work for some different website.
so the wordpress litespeed plugin is “default” lol
i though because i use litespeed or because i use wordpress manager from cyberpanel it will have preconfiguration lol
