romain
#1
It is about all the sites, the vhost are OK like this:
rewrite {
enable 1
autoLoadHtaccess 1
But the rules are not applied using htaccess.
A php file setting header rules works fine but not the htaccess rule equivalent.
Did you restart OpenLiteSpeed, do you know that if rules change OpenLiteSpeed restart is required?
More details on https://cyberpanel.net/2018/09/10/openlitespeed-v1-4-38-has-been-released/
Hello
I am also having same problems, autoLoadHtaccess does not work correctly, problems on all sites that have subfolders
qtwrk
#4
could you guys provide a more clearly example for us to check ?
romain
#5
Restart LSWS is always the good way to apply any change
