Hi, i’ve been trying to install cyberpanel cause i’m looking for an admin panel that functions good. I’ve tried ISPConfig and i’m curious about cyberpanel.
Now i’ve had a error before but i fixed that through the right dependencies… now last error before it’s all fixed is the mysql root password change that doesn’t work…
See below:
Provider: Trans-iX
System: Ubuntu 18.04 …etc
Installation option:
OLS or Enterprise?
OLS
Tried both
no
Yes
Install LiteSpeed Memcached?
Yes
Install Memcached?
Ye
yes
Install Redis?
yes
Problem:
I’ve been trying to install it multiple times… didn’t work. Every time i need to delete the /etc/cyberpanel folder and the install folder…
The error that comes up now is:
[03-43-00-Mon-Feb-2019] MYSQL Root Password change. [changeMYSQLRootPassword]
[03-43-00-Mon-Feb-2019] #########################################################################
ERROR 1045 (28000): Access denied for user ‘root’@‘localhost’ (using password: NO)
[03-43-00-Mon-Feb-2019] MYSQL Root Password change. failed, trying again, try number: 1
[03-43-00-Mon-Feb-2019] MYSQL Root Password change. failed, trying again, try number: 2
[03-43-00-Mon-Feb-2019] MYSQL Root Password change. failed, trying again, try number: 3
[03-43-00-Mon-Feb-2019] [ERROR] We are not able to MYSQL Root Password change. return code: 1. Fatal error, see /var/log/installLogs.txt for full details [changeMYSQLRootPassword]
I’ve been looking around to find a workaround to get the install to finish…
Any tips or tricks how to finish it on ubuntu 18.04.
Thanks in advance guys.
