Internal Error
The server encountered an unexpected condition which prevented it from fulfilling the request.
and when i try
/usr/local/CyberCP/bin/python manage.py makemigrations
or
/usr/local/CyberCP/bin/python manage.py migrate
i got this error
[root@chamanweb CyberCP]# /usr/local/CyberCP/bin/python manage.py makemigrations
File “manage.py”, line 22, in
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/__ init__.py”, line 363, in execute_from_command_line
utility.execute()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/__ init__.py”, line 355, in execute
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 283, in run_from_argv
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 327, in execute
self.check()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 359, in check
include_deployment_checks=include_deployment_checks,
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 346, in run_checks
return checks.run_checks(**kwargs)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/checks/regist ry.py”, line 81, in run_checks
new_errors = check(app_configs=app_configs)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/checks/urls.p y”, line 16, in check_url_config
return check_resolver(resolver)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/checks/urls.p y”, line 26, in check_resolver
return check_method()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/urls/resolvers.py” , line 254, in check
for pattern in self.url_patterns:
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/utils/functional.p y”, line 35, in get
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/urls/resolvers.py” , line 405, in url_patterns
patterns = getattr(self.urlconf_module, “urlpatterns”, self.urlconf_module)
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/urls/resolvers.py” , line 398, in urlconf_module
return import_module(self.urlconf_name)
File “/usr/lib64/python2.7/importlib/init.py”, line 37, in import_module
import(name)
File “/usr/local/CyberCP/CyberCP/urls.py”, line 23, in
url(r’^websites/’,include(‘websiteFunctions.urls’)),
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/conf/urls/init .py”, line 50, in include
urlconf_module = import_module(urlconf_module)
import(name)
File “/usr/local/CyberCP/websiteFunctions/urls.py”, line 2, in
import views
File “/usr/local/CyberCP/websiteFunctions/views.py”, line 9, in
from plogical.website import WebsiteManager
File “/usr/local/CyberCP/plogical/website.py”, line 14, in
from virtualHostUtilities import virtualHostUtilities
File “/usr/local/CyberCP/plogical/virtualHostUtilities.py”, line 32, in
from CLManager.models import CLPackages
File “/usr/local/CyberCP/CLManager/models.py”, line 9, in
class CLPackages(models.Model):
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/db/models/base.py” , line 118, in new
“INSTALLED_APPS.” % (module, name)
RuntimeError: Model class CLManager.models.CLPackages doesn’t declare an explici t app_label and isn’t in an application in INSTALLED_APPS.
File "/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/_ init__.py", line 363, in execute_from_command_line
utility.execute()
self.check()
import(name)
import(name)
import views
[root@chamanweb CyberCP]# /usr/local/CyberCP/bin/python manage.py migrate Traceback (most recent call last):
utility.execute()
self.check()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/co mmands/migrate.py”, line 62, in run_checks
issues.extend(super(Command, self).run_checks(**kwargs))
import(name)
import(name)
import views
[root@chamanweb CyberCP]# /usr/local/CyberCP/bin/python manage.py makemigrations ^C
File "/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ init_.py", line 363, in execute_from_command_line
utility.execute()
self.check()
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/co mmands/migrate.py”, line 62, in _run_checks
issues.extend(super(Command, self)._run_checks(**kwargs))
File “/usr/local/CyberCP/lib/python2.7/site-packages/django/core/management/ba se.py”, line 346, in _run_checks
import(name)
import(name)
import views
