when you want to install Prestashop via the installer, you can prive a prefix for db tables. Default and proposed one is “ps_”
Although you modify it, the installer always use “ps_” I simply did this check opening PHPMyAdmin
- CP version: 2.0 Build 3
- Host: Ubuntu 18.04
- PHP version for the website: 7.2
- SSL ok
