However, after following these simple directions, the slave server does not sync with the master. I’ve created a new site with DNS on the master but after 24 hours there are no zones on the slave. There is nothing when I try “journalctl -f | grep pdns” shows nothing.
What should I do to troubleshoot this? Like I said, everything was successful and there’s only a couple of steps so I have no idea what to do now.
So after looking into the configuration files and seeing examples of setting up PowerDNS for replication from master to slave, I can see that Cyberpanel has not set this up at all as it should have. Effectively, PowerDNS server/client doesn’t work on Cyberpanel using the web admin. It appears that besides the web server which works well, many of the more advanced features of Cyberpanel are simply broken. PowerDNS replication fails silently though it reports success, email doesn’t work, nameservers don’t work until extensive reconfiguration is performed on records. It’s only been a short time but I’m sure I’d find more if I looked. Time to go back to Virtualmin, where these things just work.
So, this was from November 2019. Fast-Forward nine months to August 2020, and I’m having the same issue as @benzod. This thread seems to have been abandoned, and no one from @CyberPanel ever chimed in. What’s the deal?
Same here! After going through a few of these forum posts, it’s become clear that these folks only answer paid customers. Forum members are the ones mostly trying to help one another, not CyberPanel folks.
