Postfix is running with backwards-compatible default settings
postfix: See Postfix Backwards-Compatibility Safety Net for details
postfix: To disable backwards compatibility use “postconf compatibility_level=2” and “postfix reload”
/usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
/usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
/usr/sbin/postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
/usr/sbin/postconf: warning: /etc/postfix/main.cf: undefined parameter: virtual_mailbox_limit_maps
/usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_create_maildirsize=yes
/usr/sbin/postconf: warning: /etc/postfix/main.cf: unused parameter: virtual_maildir_extended=yes
postfix/postfix-script: warning: symlink leaves directory: /etc/postfix/./makedefs.out
postfix/postfix-script: warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R4.pem and /etc/ssl/certs/GTS_Root_R4.pem differ
postfix/postfix-script: warning: /var/spool/postfix/etc/ssl/certs/GlobalSign_ECC_Root_CA_-R4.pem and /etc/ssl/certs/GlobalSign_ECC_Root_CA-_R4.pem differ
postfix/postfix-script: warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R2.pem and /etc/ssl/certs/GTS_Root_R2.pem differ
postfix/postfix-script: warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R3.pem and /etc/ssl/certs/GTS_Root_R3.pem differ
postfix/postfix-script: warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R1.pem and /etc/ssl/certs/GTS_Root_R1.pem differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_nis-2.31.so and /lib/x86_64-linux-gnu/libnss_nis-2.31.so differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_files-2.31.so and /lib/x86_64-linux-gnu/libnss_files-2.31.so differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_hesiod-2.31.so and /lib/x86_64-linux-gnu/libnss_hesiod-2.31.so differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_compat-2.31.so and /lib/x86_64-linux-gnu/libnss_compat-2.31.so differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_nisplus-2.31.so and /lib/x86_64-linux-gnu/libnss_nisplus-2.31.so differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libgcc_s.so.1 and /lib/x86_64-linux-gnu/libgcc_s.so.1 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_systemd.so.2 and /lib/x86_64-linux-gnu/libnss_systemd.so.2 differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_dns-2.31.so and /lib/x86_64-linux-gnu/libnss_dns-2.31.so differ
postfix/postfix-script: warning: /var/spool/postfix/lib/x86_64-linux-gnu/libresolv-2.31.so and /lib/x86_64-linux-gnu/libresolv-2.31.so differ
postfix/postfix-script: starting the Postfix mail system
root@prosalsk:~# apt-get install ols-pagespeed
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following packages were automatically installed and are no longer required:
libpcre2-posix2 linux-headers-5.4.0-132 linux-headers-5.4.0-132-generic linux-headers-5.4.0-135 linux-headers-5.4.0-135-generic linux-headers-5.4.0-137 linux-headers-5.4.0-137-generic linux-headers-5.4.0-139
linux-headers-5.4.0-139-generic linux-headers-5.4.0-149 linux-headers-5.4.0-149-generic linux-headers-5.4.0-159 linux-headers-5.4.0-159-generic linux-headers-5.4.0-163 linux-headers-5.4.0-163-generic linux-headers-5.4.0-84
linux-headers-5.4.0-84-generic linux-headers-5.4.0-88 linux-headers-5.4.0-88-generic linux-headers-5.4.0-89 linux-headers-5.4.0-89-generic linux-image-5.4.0-132-generic linux-image-5.4.0-135-generic linux-image-5.4.0-137-generic
linux-image-5.4.0-139-generic linux-image-5.4.0-149-generic linux-image-5.4.0-159-generic linux-image-5.4.0-163-generic linux-image-5.4.0-84-generic linux-image-5.4.0-88-generic linux-image-5.4.0-89-generic
linux-modules-5.4.0-132-generic linux-modules-5.4.0-135-generic linux-modules-5.4.0-137-generic linux-modules-5.4.0-139-generic linux-modules-5.4.0-149-generic linux-modules-5.4.0-159-generic linux-modules-5.4.0-163-generic
linux-modules-5.4.0-84-generic linux-modules-5.4.0-88-generic linux-modules-5.4.0-89-generic linux-modules-extra-5.4.0-132-generic linux-modules-extra-5.4.0-135-generic linux-modules-extra-5.4.0-137-generic
linux-modules-extra-5.4.0-139-generic linux-modules-extra-5.4.0-149-generic linux-modules-extra-5.4.0-159-generic linux-modules-extra-5.4.0-163-generic linux-modules-extra-5.4.0-84-generic linux-modules-extra-5.4.0-88-generic
linux-modules-extra-5.4.0-89-generic
Use ‘apt autoremove’ to remove them.
The following NEW packages will be installed:
ols-pagespeed
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 3,505 kB of archives.
After this operation, 17.0 MB of additional disk space will be used.
Get:1 Index of /debian/ focal/main amd64 ols-pagespeed amd64 1.7.18-2+focal [3,505 kB]
Fetched 3,505 kB in 1s (2,806 kB/s)
Selecting previously unselected package ols-pagespeed.
(Reading database … 493768 files and directories currently installed.)
Preparing to unpack …/ols-pagespeed_1.7.18-2+focal_amd64.deb …
Unpacking ols-pagespeed (1.7.18-2+focal) …
Setting up php7.3-fpm (7.3.33-14+ubuntu20.04.1+deb.sury.org+1) …
NOTICE: Not enabling PHP 7.3 FPM by default.
NOTICE: To enable PHP 7.3 FPM in Apache2 do:
NOTICE: a2enmod proxy_fcgi setenvif
NOTICE: a2enconf php7.3-fpm
NOTICE: You are seeing this message because you have apache2 package installed.
Job for php7.3-fpm.service failed because the control process exited with error code.
See “systemctl status php7.3-fpm.service” and “journalctl -xe” for details.
invoke-rc.d: initscript php7.3-fpm, action “restart” failed.
● php7.3-fpm.service - The PHP 7.3 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php7.3-fpm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-12-24 16:17:57 MSK; 15ms ago
Docs: man:php-fpm7.3(8)
Process: 1000115 ExecStart=/usr/sbin/php-fpm7.3 --nodaemonize --fpm-config /etc/php/7.3/fpm/php-fpm.conf (code=exited, status=78)
Process: 1000126 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.3/fpm/pool.d/www.conf 73 (code=exited, status=0/SUCCESS)
Main PID: 1000115 (code=exited, status=78)
Dec 24 16:17:57 prosalsk systemd[1]: Starting The PHP 7.3 FastCGI Process Manager…
Dec 24 16:17:57 prosalsk php-fpm7.3[1000115]: [24-Dec-2023 16:17:57] WARNING: Nothing matches the include pattern ‘/etc/php/7.3/fpm/pool.d/*.conf’ from /etc/php/7.3/fpm/php-fpm.conf at line 143.
Dec 24 16:17:57 prosalsk php-fpm7.3[1000115]: [24-Dec-2023 16:17:57] ERROR: No pool defined. at least one pool section must be specified in config file
Dec 24 16:17:57 prosalsk php-fpm7.3[1000115]: [24-Dec-2023 16:17:57] ERROR: failed to post process the configuration
Dec 24 16:17:57 prosalsk php-fpm7.3[1000115]: [24-Dec-2023 16:17:57] ERROR: FPM initialization failed
Dec 24 16:17:57 prosalsk systemd[1]: php7.3-fpm.service: Main process exited, code=exited, status=78/CONFIG
Dec 24 16:17:57 prosalsk systemd[1]: php7.3-fpm.service: Failed with result ‘exit-code’.
Dec 24 16:17:57 prosalsk systemd[1]: Failed to start The PHP 7.3 FastCGI Process Manager.
dpkg: error processing package php7.3-fpm (–configure):
installed php7.3-fpm package post-installation script subprocess returned error exit status 1
Setting up ols-pagespeed (1.7.18-2+focal) …
Setting up php5.6-fpm (5.6.40-68+ubuntu20.04.1+deb.sury.org+1) …
NOTICE: Not enabling PHP 5.6 FPM by default.
NOTICE: To enable PHP 5.6 FPM in Apache2 do:
NOTICE: a2enconf php5.6-fpm
Job for php5.6-fpm.service failed because the control process exited with error code.
See “systemctl status php5.6-fpm.service” and “journalctl -xe” for details.
invoke-rc.d: initscript php5.6-fpm, action “restart” failed.
● php5.6-fpm.service - The PHP 5.6 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php5.6-fpm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-12-24 16:18:00 MSK; 10ms ago
Docs: man:php-fpm5.6(8)
Process: 1001443 ExecStart=/usr/sbin/php-fpm5.6 --nodaemonize --fpm-config /etc/php/5.6/fpm/php-fpm.conf (code=exited, status=78)
Process: 1001445 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/5.6/fpm/pool.d/www.conf 56 (code=exited, status=0/SUCCESS)
Main PID: 1001443 (code=exited, status=78)
Dec 24 16:17:59 prosalsk systemd[1]: Starting The PHP 5.6 FastCGI Process Manager…
Dec 24 16:18:00 prosalsk php-fpm5.6[1001443]: [24-Dec-2023 16:18:00] WARNING: Nothing matches the include pattern ‘/etc/php/5.6/fpm/pool.d/*.conf’ from /etc/php/5.6/fpm/php-fpm.conf at line 15.
Dec 24 16:18:00 prosalsk php-fpm5.6[1001443]: [24-Dec-2023 16:18:00] ERROR: No pool defined. at least one pool section must be specified in config file
Dec 24 16:18:00 prosalsk php-fpm5.6[1001443]: [24-Dec-2023 16:18:00] ERROR: failed to post process the configuration
Dec 24 16:18:00 prosalsk php-fpm5.6[1001443]: [24-Dec-2023 16:18:00] ERROR: FPM initialization failed
Dec 24 16:18:00 prosalsk systemd[1]: php5.6-fpm.service: Main process exited, code=exited, status=78/CONFIG
Dec 24 16:18:00 prosalsk systemd[1]: php5.6-fpm.service: Failed with result ‘exit-code’.
Dec 24 16:18:00 prosalsk systemd[1]: Failed to start The PHP 5.6 FastCGI Process Manager.
dpkg: error processing package php5.6-fpm (–configure):
installed php5.6-fpm package post-installation script subprocess returned error exit status 1
Setting up php7.2-fpm (7.2.34-43+ubuntu20.04.1+deb.sury.org+1) …
NOTICE: Not enabling PHP 7.2 FPM by default.
NOTICE: To enable PHP 7.2 FPM in Apache2 do:
NOTICE: a2enconf php7.2-fpm
Job for php7.2-fpm.service failed because the control process exited with error code.
See “systemctl status php7.2-fpm.service” and “journalctl -xe” for details.
invoke-rc.d: initscript php7.2-fpm, action “restart” failed.
● php7.2-fpm.service - The PHP 7.2 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php7.2-fpm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-12-24 16:18:03 MSK; 12ms ago
Docs: man:php-fpm7.2(8)
Process: 1002735 ExecStart=/usr/sbin/php-fpm7.2 --nodaemonize --fpm-config /etc/php/7.2/fpm/php-fpm.conf (code=exited, status=78)
Process: 1002736 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.2/fpm/pool.d/www.conf 72 (code=exited, status=0/SUCCESS)
Main PID: 1002735 (code=exited, status=78)
Dec 24 16:18:03 prosalsk systemd[1]: Starting The PHP 7.2 FastCGI Process Manager…
Dec 24 16:18:03 prosalsk php-fpm7.2[1002735]: [24-Dec-2023 16:18:03] WARNING: Nothing matches the include pattern ‘/etc/php/7.2/fpm/pool.d/*.conf’ from /etc/php/7.2/fpm/php-fpm.conf at line 125.
Dec 24 16:18:03 prosalsk php-fpm7.2[1002735]: [24-Dec-2023 16:18:03] ERROR: No pool defined. at least one pool section must be specified in config file
Dec 24 16:18:03 prosalsk php-fpm7.2[1002735]: [24-Dec-2023 16:18:03] ERROR: failed to post process the configuration
Dec 24 16:18:03 prosalsk php-fpm7.2[1002735]: [24-Dec-2023 16:18:03] ERROR: FPM initialization failed
Dec 24 16:18:03 prosalsk systemd[1]: php7.2-fpm.service: Main process exited, code=exited, status=78/CONFIG
Dec 24 16:18:03 prosalsk systemd[1]: php7.2-fpm.service: Failed with result ‘exit-code’.
Dec 24 16:18:03 prosalsk systemd[1]: Failed to start The PHP 7.2 FastCGI Process Manager.
dpkg: error processing package php7.2-fpm (–configure):
installed php7.2-fpm package post-installation script subprocess returned error exit status 1
Setting up php7.1-fpm (7.1.33-56+ubuntu20.04.1+deb.sury.org+1) …
NOTICE: Not enabling PHP 7.1 FPM by default.
NOTICE: To enable PHP 7.1 FPM in Apache2 do:
NOTICE: a2enconf php7.1-fpm
Job for php7.1-fpm.service failed because the control process exited with error code.
See “systemctl status php7.1-fpm.service” and “journalctl -xe” for details.
invoke-rc.d: initscript php7.1-fpm, action “restart” failed.
● php7.1-fpm.service - The PHP 7.1 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php7.1-fpm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-12-24 16:18:05 MSK; 10ms ago
Docs: man:php-fpm7.1(8)
Process: 1004018 ExecStart=/usr/sbin/php-fpm7.1 --nodaemonize --fpm-config /etc/php/7.1/fpm/php-fpm.conf (code=exited, status=78)
Process: 1004019 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.1/fpm/pool.d/www.conf 71 (code=exited, status=0/SUCCESS)
Main PID: 1004018 (code=exited, status=78)
Dec 24 16:18:05 prosalsk systemd[1]: Starting The PHP 7.1 FastCGI Process Manager…
Dec 24 16:18:05 prosalsk php-fpm7.1[1004018]: [24-Dec-2023 16:18:05] WARNING: Nothing matches the include pattern ‘/etc/php/7.1/fpm/pool.d/*.conf’ from /etc/php/7.1/fpm/php-fpm.conf at line 125.
Dec 24 16:18:05 prosalsk php-fpm7.1[1004018]: [24-Dec-2023 16:18:05] ERROR: No pool defined. at least one pool section must be specified in config file
Dec 24 16:18:05 prosalsk php-fpm7.1[1004018]: [24-Dec-2023 16:18:05] ERROR: failed to post process the configuration
Dec 24 16:18:05 prosalsk php-fpm7.1[1004018]: [24-Dec-2023 16:18:05] ERROR: FPM initialization failed
Dec 24 16:18:05 prosalsk systemd[1]: php7.1-fpm.service: Main process exited, code=exited, status=78/CONFIG
Dec 24 16:18:05 prosalsk systemd[1]: php7.1-fpm.service: Failed with result ‘exit-code’.
Dec 24 16:18:05 prosalsk systemd[1]: Failed to start The PHP 7.1 FastCGI Process Manager.
dpkg: error processing package php7.1-fpm (–configure):
installed php7.1-fpm package post-installation script subprocess returned error exit status 1
Setting up php7.0-fpm (7.0.33-68+ubuntu20.04.1+deb.sury.org+2) …
NOTICE: Not enabling PHP 7.0 FPM by default.
NOTICE: To enable PHP 7.0 FPM in Apache2 do:
NOTICE: a2enconf php7.0-fpm
Job for php7.0-fpm.service failed because the control process exited with error code.
See “systemctl status php7.0-fpm.service” and “journalctl -xe” for details.
invoke-rc.d: initscript php7.0-fpm, action “restart” failed.
● php7.0-fpm.service - The PHP 7.0 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php7.0-fpm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2023-12-24 16:18:08 MSK; 14ms ago
Docs: man:php-fpm7.0(8)
Process: 1005303 ExecStart=/usr/sbin/php-fpm7.0 --nodaemonize --fpm-config /etc/php/7.0/fpm/php-fpm.conf (code=exited, status=78)
Process: 1005304 ExecStopPost=/usr/lib/php/php-fpm-socket-helper remove /run/php/php-fpm.sock /etc/php/7.0/fpm/pool.d/www.conf 70 (code=exited, status=0/SUCCESS)
Main PID: 1005303 (code=exited, status=78)
Dec 24 16:18:08 prosalsk systemd[1]: Starting The PHP 7.0 FastCGI Process Manager…
Dec 24 16:18:08 prosalsk php-fpm7.0[1005303]: [24-Dec-2023 16:18:08] WARNING: Nothing matches the include pattern ‘/etc/php/7.0/fpm/pool.d/*.conf’ from /etc/php/7.0/fpm/php-fpm.conf at line 125.
Dec 24 16:18:08 prosalsk php-fpm7.0[1005303]: [24-Dec-2023 16:18:08] ERROR: No pool defined. at least one pool section must be specified in config file
Dec 24 16:18:08 prosalsk php-fpm7.0[1005303]: [24-Dec-2023 16:18:08] ERROR: failed to post process the configuration
Dec 24 16:18:08 prosalsk php-fpm7.0[1005303]: [24-Dec-2023 16:18:08] ERROR: FPM initialization failed
Dec 24 16:18:08 prosalsk systemd[1]: php7.0-fpm.service: Main process exited, code=exited, status=78/CONFIG
Dec 24 16:18:08 prosalsk systemd[1]: php7.0-fpm.service: Failed with result ‘exit-code’.
Dec 24 16:18:08 prosalsk systemd[1]: Failed to start The PHP 7.0 FastCGI Process Manager.
dpkg: error processing package php7.0-fpm (–configure):
installed php7.0-fpm package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
php7.3-fpm
php5.6-fpm
php7.2-fpm
php7.1-fpm
php7.0-fpm
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@prosalsk:~#
