I only have one site and did not change anything in usr/local/lsws/ folder, it is a standard centos 7 install…
The only thing I can think of now that may be the issue is I deleted the 1st site added and replaced with another however all the ssl certificates have been recreated.
I will spin up a test vps and try on a fresh install
The problem was a permission issue on /usr/local/lsws//tmp/ocspcache// , /usr/local/lsws//tmp/ and also had the /usr/local/lsws//autoupdate folders permission error
Just set to permissions to 1777 and no errors must be the Centos version Vultr use as never had the issue before when testing ubuntu.
Tested the PCI Compliance ssl test here and get A+ https://www.htbridge.com/ssl/
Only error is in Industry Best-Practices Analysis which notes http does not redirect to https but it does, have added .htaccess codes and still the same
Yes. I saw this bug in my code, also for the RPM users, we will update the script to make sure the permission is correct.
Right now, can you just run this command in the terminal to fix the issue.
