password of :7080 control panel ?
Hi , what is the password of port 7080 web control panel ?
I have tried default like 123456 and same password as I have with panel on 8090 port, all no good
and I also get this error
Warning: fopen(/usr/local/lsws/admin/conf/htpasswd): failed to open stream: Permission denied in /usr/local/lsws/admin/html.open/lib/CAuthorizer.php on line 214
also tried use this
/usr/local/lsws/admin/misc/admpass.sh
but with newly reset username and password still can’t login
never mind , problem is solved by manually run
yum remove openlitespeed
and
yum install openlitespeed
but I don’t know if there is any other things it breaks
yeah… lot of things broken , even PHP…
For PHP just include these configuration files:
include phpconfigs/php53.conf
include phpconfigs/php54.conf
include phpconfigs/php55.conf
include phpconfigs/php56.conf
include phpconfigs/php70.conf
include phpconfigs/php71.conf
and than under
usr/local/lsws/conf/phpconfigs
You can create PHP configuration files, an example for php71
extprocessor php71 {
type lsapi
address uds://tmp/lshttpd/lsphp71.sock
maxConns 50
initTimeout 60
retryTimeout 0
persistConn 1
respBuffer 0
autoStart 1
path /usr/local/lsws/lsphp71/bin/lsphp
memSoftLimit 2047M
memHardLimit 2047M
procSoftLimit 400
procHardLimit 500
currently you can see all password from cyberpanel in /etc/cyberpanel/ directory
Wow thread is almost almost 4 years old; necro thread!
