CentOS 7. Repos installed comes from CyberPanel installation. Recently I’m getting following error on yum update:
Resolving Dependencies
→ Running transaction check
—> Package oniguruma.x86_64 0:5.9.5-3.el7 will be updated
→ Processing Dependency: libonig.so.2()(64bit) for package: lsphp74-mbstring-7.4.6-1.el7.x86_64
—> Package oniguruma.x86_64 0:6.8.2-1.el7 will be an update
→ Finished Dependency Resolution
Error: Package: lsphp74-mbstring-7.4.6-1.el7.x86_64 (installed)
Requires: libonig.so.2()(64bit)
Removing: oniguruma-5.9.5-3.el7.x86_64 (@epel)
Updated By: oniguruma-6.8.2-1.el7.x86_64 (epel)
~libonig.so.5()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
