Is there an option to use my own SSL certificate that I purchased or does CyberPanel only support LetsEncrypt?
Thanks!
Thanks!
hi,
i have buy SSL comodo, how to install to cyberpanel ? because i have 4 file
domain.crt
COMODORSADomainValidationSecureServerCA.crt
COMODORSAAddTrustCA.crt
AddTrustExternalCARoot.crt
Can you help me install it ? because file domain.crt , i have paste into cert and all i have paste into key, but error
sorry my English not good
@tonyquach said:
hi,
domain.crt
AddTrustExternalCARoot.crtCan you help me install it ? because file domain.crt , i have paste into cert and all i have paste into key, but error
i have fix it
I’ve installed my own SSL, but after I restarted litespeed, i still can’t access my website. It says connection refused. I checked again the CRT and the Key, but it’s gone.
Anyone have any idea about this?
@roboticpuppies said:
I will look into this issue, meanwhile, you can edit these two files from the command line:
keyFile /usr/local/lsws/conf/vhosts/SSL-example.com/privkey.pem
certFile /usr/local/lsws/conf/vhosts/SSL-example.com/fullchain.pem
Great! thank you for the help Mr. @usmannasir . Gonna look into it.
@tonyquach said:
@tonyquach said:
hi,
domain.crt
i have fix it
How do you fix it?
