This is how I converted OrangeScrum .httaccess to OLS. This is OLS v1.6 and OrangeScrum v1.6.1. Any help getting this website to work is appreciated.
OrangeScrum has the following .htaccess files:
- ./.htaccess
- ./lib/Cake/Console/Templates/skel/.htaccess
- ./lib/Cake/Console/Templates/skel/webroot/.htaccess
- ./app/.htaccess
- ./app/webroot/.htaccess
- ./app/webroot/files/case_files/.htaccess
Orginal ./.htaccess
` RewriteEngine on RewriteRule ^$ app/webroot/ [L] RewriteRule (.*) app/webroot/$1 [L] ` ``` Static Context`context / { location $DOC_ROOT allowBrowse 1 rewrite { enable 1 RewriteRule ^$ app/webroot/ [L] RewriteRule (.*) app/webroot/$1 [L] } addDefaultCharset off }` ``` Orginal ./lib/Cake/Console/Templates/skel/.htaccess` RewriteEngine on RewriteRule ^$ webroot/ [L] RewriteRule (.*) webroot/$1 [L] ` ``` Static Context`context /lib/Cake/Console/Templates/skel/ { location $DOC_ROOT/lib/Cake/Console/Templates/skel/ allowBrowse 1 rewrite { enable 1 RewriteRule ^$ webroot/ [L] RewriteRule (.*) webroot/$1 [L] } addDefaultCharset off }` ``` Orginal ./lib/Cake/Console/Templates/skel/webroot/.htaccess` RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^ index.php [L] ` ``` Static Context`context /lib/Cake/Console/Templates/skel/webroot/ { location $DOC_ROOT/lib/Cake/Console/Templates/skel/webroot allowBrowse 1 rewrite { RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^ index.php [L] } addDefaultCharset off }` ``` Orginal ./app/.htaccess` RewriteEngine on RewriteRule ^$ webroot/ [L] RewriteRule (.*) webroot/$1 [L] # Insert filter SetOutputFilter DEFLATE # Netscape 4.x has some problems... BrowserMatch ^Mozilla/4 gzip-only-text/html # Netscape 4.06-4.08 have some more problems BrowserMatch ^Mozilla/4\\.0[678] no-gzip # MSIE masquerades as Netscape, but it is fine # BrowserMatch \\bMSIE !no-gzip !gzip-only-text/html # NOTE: Due to a bug in mod_setenvif up to Apache 2.0.48 # the above regex won't work. You can use the following # workaround to get the desired effect: BrowserMatch \\bMSI[E] !no-gzip !gzip-only-text/html # Don't compress images SetEnvIfNoCase Request_URI \\ \\.(?:gif|jpe?g|png)$ no-gzip dont-vary # Make sure proxies don't deliver the wrong content Header append Vary User-Agent env=!dont-vary ExpiresActive On Header set Expires "access 12 month" Header unset ETag FileETag None ` ``` Static Context - Could not figure this one out. This is my best guess.`context /app/ { location $DOC_ROOT/app allowBrowse 1 enableExpires 1 expiresDefault A31557600 extraHeaders Vary: User-Agent rewrite { enable 1 RewriteRule ^$ webroot/ [L] RewriteRule (.*) webroot/$1 [L] } addDefaultCharset off }` ``` Orginal ./app/webroot/.htaccess` RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^(.*)$ index.php [QSA,L] ` ``` Static Context`context /app/webroot/ { location $DOC_ROOT/app/webroot allowBrowse 1 rewrite { enable 1 RewriteCond %{REQUEST_FILENAME} !-d RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^(.*)$ index.php [QSA,L] } addDefaultCharset off }` ``` Orginal ./app/webroot/files/case_files/.htaccess`#Order Deny,Allow #Deny from all ` ``` Static Context This can be bypassed.
