OrangeHRM comes with the following .htaccess files. Any insights on how to get this website working are appreciated. I am using CyberPanel Version 1.6 and OrangeHRM v4.1.
- ./upgrader/web/.htaccess
- ./upgrader/web/images/.htaccess
- ./symfony/lib/vendor/symfony/lib/task/generator/skeleton/project/web/.htaccess
- ./symfony/lib/vendor/codeception/codeception/tests/data/app/.htaccess
- ./symfony/web/.htaccess
- ./.htaccess
- ./lib/confs/cryptokeys/.htaccess
- ./installer/images/.htaccess
Orginal ./upgrader/web/.htaccess
`Options +FollowSymLinks +ExecCGI RewriteEngine On # uncomment the following line, if you are having trouble # getting no_script_name to work #RewriteBase / # we skip all files with .something #RewriteCond %{REQUEST_URI} \\..+$ #RewriteCond %{REQUEST_URI} !\\.html$ #RewriteRule .* - [L] # we check if the .html version is here (caching) RewriteRule ^$ index.html [QSA] RewriteRule ^([^.]+)$ $1.html [QSA] RewriteCond %{REQUEST_FILENAME} !-f # no, so we redirect to our front web controller RewriteRule ^(.*)$ index.php [QSA,L] ` ``` Static Context`context /upgrader/web/ { location $DOC_ROOT/upgrader/web allowBrowse 1 rewrite { enable 1 RewriteRule ^$ index.html [QSA] RewriteRule ^([^.]+)$ $1.html [QSA] RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^(.*)$ index.php [QSA,L] } addDefaultCharset off }` ``` Orgainal ./upgrader/web/images/.htacces` order allow,deny deny from all ` ``` Static Context`context /upgrader/web/images/dummy.jpg { location $DOC_ROOT/upgrader/web/images allowBrowse 0 addDefaultCharset off }` ``` Orgainal ./symfony/lib/vendor/symfony/lib/task/generator/skeleton/project/web/.htaccess`Options +FollowSymLinks +ExecCGI RewriteEngine On # uncomment the following line, if you are having trouble # getting no_script_name to work #RewriteBase / # we skip all files with .something #RewriteCond %{REQUEST_URI} \\..+$ #RewriteCond %{REQUEST_URI} !\\.html$ #RewriteRule .* - [L] # we check if the .html version is here (caching) RewriteRule ^$ index.html [QSA] RewriteRule ^([^.]+)$ $1.html [QSA] RewriteCond %{REQUEST_FILENAME} !-f # no, so we redirect to our front web controller RewriteRule ^(.*)$ index.php [QSA,L] ` ``` Static Context`context /symfony/lib/vendor/symfony/lib/task/generator/skeleton/project/web/ { location $DOC_ROOT/symfony/lib/vendor/symfony/lib/task/generator/skeleton/project/web/ allowBrowse 1 rewrite { enable 1 RewriteRule ^$ index.html [QSA] RewriteRule ^([^.]+)$ $1.html [QSA] RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^(.*)$ index.php [QSA,L] } addDefaultCharset off } ` ``` Orginal ./symfony/lib/vendor/codeception/codeception/tests/data/app/.htaccess`RewriteEngine On RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule . /index.php ` ``` Static Context`context /symfony/lib/vendor/codeception/codeception/tests/data/app/ { location $DOC_ROOT/symfony/lib/vendor/codeception/codeception/tests/data/app/ allowBrowse 1 rewrite { RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule . /index.php } addDefaultCharset off }` ``` Orginal ./symfony/web/.htaccess`#Options +FollowSymLinks +ExecCGI RewriteEngine On # uncomment the following line, if you are having trouble # getting no_script_name to work #RewriteBase / # we skip all files with .something #RewriteCond %{REQUEST_URI} \\..+$ #RewriteCond %{REQUEST_URI} !\\.html$ #RewriteRule .* - [L] # we check if the .html version is here (caching) RewriteRule ^$ index.html [QSA] RewriteRule ^([^.]+)$ $1.html [QSA] RewriteCond %{REQUEST_FILENAME} !-f # no, so we redirect to our front web controller RewriteRule ^(.*)$ index.php [QSA,L] # security Header set X-Content-Type-Options nosniff Header set X-XSS-Protection "1; mode=block" ` ``` Static Context`context /symfony/web/ { location $DOC_ROOT/symfony/web/ allowBrowse 1 extraHeaders <<<END_extraHeaders X-Content-Type-Options: nosniff X-XSS-Protection: 1, mode=block END_extraHeaders rewrite { enable 1 RewriteRule ^$ index.html [QSA] RewriteRule ^([^.]+)$ $1.html [QSA] RewriteCond %{REQUEST_FILENAME} !-f RewriteRule ^(.*)$ index.php [QSA,L] } addDefaultCharset off }` ``` Orginal ./.htaccess`IndexIgnore * order allow,deny deny from all order allow,deny deny from all order allow,deny deny from all order allow,deny deny from all ` ``` Static Context (need two)`context / { location $DOC_ROOT allowBrowse 1 autoIndex 0 addDefaultCharset off }` ````context exp: ^/(log.txt|*.log|log*.txt|*.yml) { location $DOC_ROOT allowBrowse 0 rewrite { } addDefaultCharset off }` ``` Orginal ./lib/confs/cryptokeys/.htaccess` Order allow,deny Deny from all ` ``` Static Context` context /lib/confs/cryptokeys/key.ohrm { location $DOC_ROOT/lib/confs/cryptokeys allowBrowse 0 addDefaultCharset off } ` ``` Orginal ./installer/images/.htaccess` order allow,deny deny from all ` ``` Static Context`context /installer/images/dummy.jpg { location $DOC_ROOT/installer/images allowBrowse 0 addDefaultCharset off }` ```
