Hello, I installed OpenLiteSpeed with CyberPanel and I need to add
Options +FollowSymLinks
in .htaccess to change the prettyurls of every WordPress site.
I have also an issue with mails port 25 and 587 are connected with example.com and 465 can’t connect to localhost.
Can anybody help me please ?
It does not send any mail with a simple php script.
Hi, could you be a little more specific about 465 port ?
for symlink ,
- follow this to be able to access to webadmin console https://forums.cyberpanel.net/discussion/87/tutorial-how-to-setup-and-login-to-openlitespeed-webadmin-console#latest
- As screenshots indicates , go to virtual hosts , your-domain , basic
All domains follow their symlinks.
I tried to remove the Options +FollowSymLinks and still it follows. It seems ok now.
About ports I can’t send any mail from any site.
I am trying to understand why with a WP plugin named Post SMTP.
I try my Internet Provider’s SMTP and my registar’s SMTP but all fails to connect to the right server.
Ports seems like this :
Before sending email from a php script, run following on CLI
journalctl -f | grep postfix
After sending paste the output from command line.
I received this email “4.7.1 : Relay access denied”
Can you please email all related login information to : support [@] cyberpanel [dot] net
Or join our discord channel from top right corner, also mention the steps to reproduce the problem.
Regards
postfix/anvil[2070]: statistics: max connection rate 1/60s for (smtp:80.82.70.210)
postfix/anvil[2070]: statistics: max connection count 1 for (smtp:80.82.70.210)
postfix/anvil[2070]: statistics: max cache size 1
from=[email protected], size=380, nrcpt=1 (queue active)
host mx1.mail.ovh.net[188.165.36.237] said: 450 4.1.8 [email protected]:
Sender address rejected: Domain not found (in reply to RCPT TO command)
96C5BD80847: to=[email protected], relay=mx2.mail.ovh.net[87.98.160.167]:25, delay=4779, delays=4772/0.06/6.7/0.34, dsn=4.1.8, status=deferred (host mx2.mail.ovh.net[87.98.160.167] said: 450 4.1.8
[email protected]: Sender address rejected: Domain not found (in reply to RCPT TO command))
Test this:
Edit /etc/postfix/main.cf … line ~681 “myhostname” and change server.example.com with your domain. Then restart postfix ( service postfix restart).
Can you tell us the name of the WP plugin too?
This plugin is Post SMTP. https://postmansmtp.com/
Changing “myhostname” like this is working! I have put my smtp provider and it works.
My sites can send email now.
Solved.
Another issue with SymLink. I created a subdomain with path to root. I checked :
Follow Symbolic Link Yes
But the subdomain site (in Wordpress multisite configuration) does not follow the symlinks. It works only in basic Wordpress linking system. The main domain works.
I also have enabled Wordpress multisite for another domain with sub directory. It show a page with almost nothing : no css pictures, etc. because of Failed to load resource: the server responded with a status of 404 () The main domain works.
You need to update rewrite rules for WordPress multisite to work:
Subfolder : The trailing slash is OK. HTTPS is OK too. wp-admin has ERR_TOO_MANY_REDIRECTS
Subdomain : no change. Can NOT do prettyUrl only in subdomain.
I also did as mentioned here htaccess « WordPress Codex
Submit with complete details to: https://cyberpanel.net/support/
if i enabled follow symlink , shall i edit .htaccess?
@romain said:
Another issue with SymLink. I created a subdomain with path to root. I checked :Follow Symbolic Link YesBut the subdomain site (in Wordpress multisite configuration) does not follow the symlinks. It works only in basic Wordpress linking system. The main domain works.
Failed to load resource: the server responded with a status of 404 ()The main domain works.
what do you mean “basic WP linking system” ?
what exactly are you want to archive ?
No really , if you enable it in webadmin console .
actually , in .htaccess , any content that is not rewrite rule , OLS just will ignore it as it doesn’t understand it
