Again for 10 times openlitespeed stopped working …
I don’t know why but there is important problem in openlitespeed that’s not working and stopping suddenly…
in the past , when every time that stopped , I had no choice to install cyberpanel again , but now there is more complicated to install it on clean os ! and I dont have any Idea to fix this problem
I just think this problem is related to the vhost config file
root@secondserverhpe:~# sudo systemctl status lsws
● lshttpd.service - OpenLiteSpeed HTTP Server
Loaded: loaded (/etc/systemd/system/lshttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2023-01-19 13:46:30 +0330; 16min ago
Process: 1498 ExecStart=/usr/local/lsws/bin/lswsctrl start (code=exited, status=0/SUCCESS)
Main PID: 1811 (litespeed)
CGroup: /system.slice/lshttpd.service
├─1811 ./litespeed
└─1814 openlitespeed (lscgid)
Jan 19 13:46:28 secondserverhpe systemd[1]: Starting OpenLiteSpeed HTTP Server...
Jan 19 13:46:28 secondserverhpe lswsctrl[1498]: [OK] Send SIGUSR1 to 1266
Jan 19 13:46:29 secondserverhpe systemd[1]: lshttpd.service: Can't open PID file /run/openlitespeed.pid (yet?)>
Jan 19 13:46:30 secondserverhpe systemd[1]: Started OpenLiteSpeed HTTP Server.
Jan 19 13:46:30 secondserverhpe lswsctrl[1181]: [OK] litespeed: pid=1811.
Most of the time its usually a php process issue where some processes loop or hang. Do you have WordPress website or php websites that consume memory or run several plugins?
Also are you consuming redis from your websites /webapps? I am seeling redis is running on your server
Yes . All of site are running wordpress
As you know , in wordpress we need plugin but I try to use less plugin as I can.
During the installation of cyberpanel , redis ask to install and I accept that but I use the Memcache because I think its compatible with the Litespeed or Openlitespeed and plugin for wordpress from this company and have no Idea why its running , if its useless , I remove the redis to avoid this problem again…
and if I switch to LiteSpeed ENT , dos it happen agian ?
I mean is that related to free webserver ? and if I paid for it , dos it going to truble?
Uninstall if you do not need it. Save your resources
Yes it might. Purchasing litespeed does not mean bugs are patched while in OLS bugs arent. Customers always misunderstand the difference between Litespeed and OLS. LiteSpeed is best for users who want extras only such as esi support etc. From my own experience LiteSpeed is best used alone not with cyberpanel. That’s the only way to maximize what you pay for.
