possible to get access to web interface of litespeed?
does not work for me
have set admin pass with script and enabled port in firewall
still no access to it
If you are using Google cloud they have an external firewall too.
no there is not other firewall i think
cant reach
2018-07-18 08:32:46.001095 [NOTICE] [Child: 23812] Setup swapping space…
2018-07-18 08:32:46.001139 [NOTICE] [Child: 23812] LiteSpeed/1.4.34 Open starts successfully!
2018-07-18 08:32:50.775456 [NOTICE] [AutoRestarter] child process with pid=23812 received signal=11, a core file is created!
2018-07-18 08:32:50.784936 [NOTICE] [AutoRestarter] cleanup children processes and unix sockets belong to process 23812 !
2018-07-18 08:32:50.885502 [NOTICE] [AutoRestarter] new child process with pid=23835 is forked!
2018-07-18 08:32:50.885689 [INFO] Stop listener *:7080.
2018-07-18 08:32:50.885895 [NOTICE] [child: 23835] Successfully change current user to nobody
2018-07-18 08:32:50.885908 [NOTICE] Child: 23835] Core dump is enabled.
2018-07-18 08:32:50.885923 [NOTICE] [Child: 23835] Setup swapping space…
2018-07-18 08:32:50.885951 [NOTICE] [Child: 23835] LiteSpeed/1.4.34 Open starts successfully!
2018-07-18 08:32:58.702303 [NOTICE] [AutoRestarter] child process with pid=23835 received signal=11, a core file is created!
2018-07-18 08:32:58.711013 [NOTICE] [AutoRestarter] cleanup children processes and unix sockets belong to process 23835 !
2018-07-18 08:32:58.811579 [NOTICE] [AutoRestarter] new child process with pid=23854 is forked!
2018-07-18 08:32:58.811789 [INFO] Stop listener *:7080.
2018-07-18 08:32:58.811934 [NOTICE] [child: 23854] Successfully change current user to nobody
2018-07-18 08:32:58.811944 [NOTICE] Child: 23854] Core dump is enabled.
2018-07-18 08:32:58.811957 [NOTICE] [Child: 23854] Setup swapping space…
2018-07-18 08:32:58.811980 [NOTICE] [Child: 23854] LiteSpeed/1.4.34 Open starts successfully!
2018-07-18 08:32:59.934147 [NOTICE] [AutoRestarter] child process with pid=23854 received signal=11, a core file is created!
2018-07-18 08:32:59.943744 [NOTICE] [AutoRestarter] cleanup children processes and unix sockets belong to process 23854 !
2018-07-18 08:33:00.000533 [NOTICE] [AutoRestarter] new child process with pid=23873 is forked!
2018-07-18 08:33:00.000733 [INFO] Stop listener *:7080.
2018-07-18 08:33:00.000906 [NOTICE] [child: 23873] Successfully change current user to nobody
2018-07-18 08:33:00.000917 [NOTICE] Child: 23873] Core dump is enabled.
2018-07-18 08:33:00.000929 [NOTICE] [Child: 23873] Setup swapping space…
2018-07-18 08:33:00.000954 [NOTICE] [Child: 23873] LiteSpeed/1.4.34 Open starts successfully!
2018-07-18 08:33:03.784988 [NOTICE] [AutoRestarter] child process with pid=23873 received signal=11, a core file is created!
2018-07-18 08:33:03.794439 [NOTICE] [AutoRestarter] cleanup children processes and unix sockets belong to process 23873 !
2018-07-18 08:33:03.895011 [NOTICE] [AutoRestarter] new child process with pid=23890 is forked!
2018-07-18 08:33:03.895170 [INFO] Stop listener *:7080.
2018-07-18 08:33:03.895314 [NOTICE] [child: 23890] Successfully change current user to nobody
2018-07-18 08:33:03.895335 [NOTICE] Child: 23890] Core dump is enabled.
2018-07-18 08:33:03.895357 [NOTICE] [Child: 23890] Setup swapping space…
2018-07-18 08:33:03.895382 [NOTICE] [Child: 23890] LiteSpeed/1.4.34 Open starts successfully!
2018-07-18 08:33:32.793311 [NOTICE] [AutoRestarter] child process with pid=23890 received signal=11, a core file is created!
2018-07-18 08:33:32.825077 [NOTICE] [AutoRestarter] cleanup children processes and unix sockets belong to process 23890 !
2018-07-18 08:33:32.925644 [NOTICE] [AutoRestarter] new child process with pid=23921 is forked!
2018-07-18 08:33:32.925828 [INFO] Stop listener *:7080.
2018-07-18 08:33:32.925971 [NOTICE] [child: 23921] Successfully change current user to nobody
2018-07-18 08:33:32.925982 [NOTICE] Child: 23921] Core dump is enabled.
2018-07-18 08:33:32.925994 [NOTICE] [Child: 23921] Setup swapping space…
2018-07-18 08:33:32.926018 [NOTICE] [Child: 23921] LiteSpeed/1.4.34 Open starts successfully!
2018-07-18 08:33:35.947662 [NOTICE] [AutoRestarter] child process with pid=23921 received signal=11, a core file is created!
2018-07-18 08:33:35.957026 [NOTICE] [AutoRestarter] cleanup children processes and unix sockets belong to process 23921 !
2018-07-18 08:33:36.000577 [NOTICE] [AutoRestarter] new child process with pid=23936 is forked!
2018-07-18 08:33:36.000794 [INFO] Stop listener *:7080.
2018-07-18 08:33:36.000960 [NOTICE] [child: 23936] Successfully change current user to nobody
2018-07-18 08:33:36.000971 [NOTICE] Child: 23936] Core dump is enabled.
2018-07-18 08:33:36.000984 [NOTICE] [Child: 23936] Setup swapping space…
2018-07-18 08:33:36.001010 [NOTICE] [Child: 23936] LiteSpeed/1.4.34 Open starts successfully!
At [18/Jul/2018:20:53:16 +0200], web server with pid=24694 received unexpected signal=11, a core file is created. A new instance of web server will be started automatically!
Please forward the following debug information to bug@litespeedtech.com.
Environment:
Server: LiteSpeed/1.4.34 Open
OS: Linux
Release: 3.10.0-693.el7.x86_64
Version: #1 SMP Tue Aug 22 21:09:27 UTC 2017
Machine: x86_64
If the call stack information does not show up here, please compress and forward the core file located in /tmp/lshttpd.
