I have tried all the commands in…
/usr/local/lsws/bin/lswsctrl help
After using " systemctl status lshttpd.service "
After using " journalctl -xe "
Share journalctl logs here, not able to open prnt.sc site.
Can’t see anything useful, can you share your story as to how it happened? you did something or is it fresh install?
Its a fresh Installation today morning. Then I am customizing my website then it happened.
BTW, what is the sense there in the journalctl logs like " Automatic restarting of the unit lshttpd.service, then a time "
Hey @asma are you able to understand the problem?
this is the error log…
https://drive.google.com/file/d/1XgqYHvmNEoU9ndAXdfliBV0-oFJTU7On/view?usp=sharing
Do you have user nobody and nogroup in your system? Is it Ubuntu?
Yes its Ubuntu. I don’t know, I have just Installed cyberpanel from Linode.
Now, I am re installing the cyber panel.
Can you install on fresh OS using → 01 - Installing CyberPanel - Docs - CyberPanel Community
Thanks @asma I have Installed CyberPanel again in a fresh OS ( Centos 7 ). Now its working perfectly.
