[NOTICE] [715406] Shut down successfully!
Hi, I don’t understand what is this log. Is my server keep restarting? Can someone please help and tell me how to clean /tmp?
2021-12-18 13:33:01.530803 [NOTICE] [715406] New litespeed process is ready, stops listeners
2021-12-18 13:33:01.530824 [INFO] [715406] Stop all listeners.
2021-12-18 13:33:01.530827 [NOTICE] [715406] Stop listener *:443, fd 13.
2021-12-18 13:33:01.530831 [NOTICE] [715406] Stop listener *:80, fd 9.
2021-12-18 13:33:01.531307 [NOTICE] [873736] [psjai7109.990] add child process pid: 873748
2021-12-18 13:33:01.531367 [INFO] [873736] [psjai7109.990]: unlocked pid file [/tmp/lshttpd/psjai7109.sock.pid].
2021-12-18 13:33:01.531393 [NOTICE] [873736] Setup swapping space…
2021-12-18 13:33:01.531454 [NOTICE] [873736] LiteSpeed/1.7.12 Open
module versions:
modgzip 1.1
cache 1.62
modinspector 1.1
uploadprogress 1.1
mod_security 1.4
starts successfully!
2021-12-18 13:33:01.535444 [NOTICE] [715404] New litespeed process is ready, stops listeners
2021-12-18 13:33:01.535465 [INFO] [715404] Stop all listeners.
2021-12-18 13:33:01.535468 [NOTICE] [715404] Stop listener *:80, fd 7.
2021-12-18 13:33:01.535473 [NOTICE] [715404] Stop listener *:443, fd 11.
2021-12-18 13:33:01.535476 [NOTICE] [715404] Stop listener *:7080, fd 19.
2021-12-18 13:33:02.886742 [INFO] [873737] RewriteFile [/home/smartgametech.com/public_html/wp-content/.htaccess] parsed, return 0.
2021-12-18 13:33:02.886793 [INFO] [873737] RewriteFile [/home/smartgametech.com/public_html/wp-content/uploads/.htaccess] parsed, return 0.
2021-12-18 13:33:20.838319 [NOTICE] [715407] Event-loop lingering done.
2021-12-18 13:33:20.838347 [NOTICE] [715407] Shut down successfully!
2021-12-18 13:33:20.838353 [NOTICE] [715407] HttpServerImpl::releaseAll called.
2021-12-18 13:33:20.841498 [NOTICE] [715372] [AutoRestarter] cleanup children processes and unix sockets belong to process 715407 !
2021-12-18 13:33:20.941877 [NOTICE] [715372] [AutoRestarter] child process with pid=715407 exited with status=0!
2021-12-18 13:33:47.464277 [NOTICE] [715405] Event-loop lingering done.
2021-12-18 13:33:47.464292 [NOTICE] [715405] Shut down successfully!
2021-12-18 13:33:47.464298 [NOTICE] [715405] HttpServerImpl::releaseAll called.
2021-12-18 13:33:47.467046 [NOTICE] [715372] [AutoRestarter] cleanup children processes and unix sockets belong to process 715405 !
2021-12-18 13:33:47.567131 [NOTICE] [715372] [AutoRestarter] child process with pid=715405 exited with status=0!
2021-12-18 13:34:23.986165 [NOTICE] [715404] Event-loop lingering done.
2021-12-18 13:34:23.986249 [NOTICE] [715404] Shut down successfully!
2021-12-18 13:34:23.986258 [NOTICE] [715404] HttpServerImpl::releaseAll called.
2021-12-18 13:34:23.990237 [NOTICE] [715372] [AutoRestarter] cleanup children processes and unix sockets belong to process 715404 !
2021-12-18 13:34:24.000194 [NOTICE] [715372] [AutoRestarter] child process with pid=715404 exited with status=0!
2021-12-18 13:34:46.556991 [NOTICE] [715406] Event-loop lingering done.
2021-12-18 13:34:46.557009 [NOTICE] [715406] Shut down successfully!
2021-12-18 13:34:46.557014 [NOTICE] [715406] HttpServerImpl::releaseAll called.
2021-12-18 13:34:46.560329 [NOTICE] [715372] [AutoRestarter] cleanup children processes and unix sockets belong to process 715406 !
2021-12-18 13:34:46.660449 [NOTICE] [715372] [AutoRestarter] child process with pid=715406 exited with status=0!
2021-12-18 13:34:46.660519 [NOTICE] [715372] Server Stopped!
2021-12-18 13:38:30.147583 [INFO] [873739] RewriteFile [/home/smartgametech.com/public_html/wp-content/.htaccess] parsed, return 0.
2021-12-18 13:38:48.271044 [INFO] [873739] RewriteFile [/home/smartgametech.com/public_html/wp-content/uploads/.htaccess] parsed, return 0.
2021-12-18 13:41:46.664598 [INFO] [873736] RewriteFile [/home/smartgametech.com/public_html/wp-content/.htaccess] parsed, return 0.
2021-12-18 13:41:46.664643 [INFO] [873736] RewriteFile [/home/smartgametech.com/public_html/wp-content/uploads/.htaccess] parsed, return 0.
2021-12-18 13:41:46.684028 [INFO] [873738] RewriteFile [/home/smartgametech.com/public_html/wp-content/.htaccess] parsed, return 0.
2021-12-18 13:41:46.684070 [INFO] [873738] RewriteFile [/home/smartgametech.com/public_html/wp-content/uploads/.htaccess] parsed, return 0.
2021-12-18 .093206 [NOTICE] [873739] [SSLTicket] ticketCb() SHM keys 13:44:18need rotation
Thank you so much in advance!
Its a short time span log and we cannot judge anything much. Every process gets recorded in logs.
Thank you so much for your reply. Can you please answer my few questions-
Should I worry about ([NOTICE] [715406] Shut down successfully! and Server Stopped! which I can see in my server error log?
I can see “lsphp” using %CPU-100 sometime. How Can I figure it out?
Some people say clear /tmp, can you please guide how can I clear. I’m asking these questions because my server load graph above 100%. It’s hard to figure out for me what’s wrong, Any help greatly appreciated.
Also whenever I switch my PHP version 7.4 to 8.0. I can see zip missing module error. I uploaded some snapshots.
If there is frequent reboot of your server, then you should worry about it. If the reboots are intentionally done for purpose, then its obvious you will see those entries in log.
I cant actually make a point here unless I see the logs in detail and for greater time span period of logs collected.
Lsphp using more resources maybe some script level bottleneck or usage. What all type of sites are you using? Is it only wordpress and how many sites hosted? What is your server configuration? Who is your hosting provider?
Are you running ecommerce site?
My hosting provider - Linode
It’s only WordPress and hosted two websites.
Server Configuration - default.
I have one eCommerce website with 0 visitors.
How can I share my logs with you?
Sorry my server hardware is - 4 CPU Core and 8GB RAM
Do check this if it maybe the reason. What should I do if my website is slow? - #7 by lismo
