Hello there,
A week ago, I changed my host.
When my site was on ‘old host’ (WPEngine), I used Proxied Cloudflare connection.
Once moved to the ‘new host’ (LiquidWeb), I switched back on the proxied connection.
Once the connection is proxied, it still shows the content on my old host.
Once I turn off the Proxied connection, it shows my new host.
Has anyone faced something like this?
I’d love to know if there’s a solution for this.
Hello, try changing your ssl from cloudflore to flexible mode. Then go to the cache settings and try to “clear the saved cache” (if possible enable developer mode during migration) and especially, if you use proxy and ssl from cludflare, you should disable the auto signed server.
