I am not able to install CyberPanel on DigitalOcean Droplet running Centos7 2gb ram 2vCPU
[root@cyberpanel ~]# wget http://cyberpanel.net/install.tar.gz
-bash: wget: command not found
[root@cyberpanel ~]# tar zxf install.tar.gz
tar (child): install.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
[root@cyberpanel ~]# cd install
-bash: cd: install: No such file or directory
[root@cyberpanel ~]# chmod +x install.py
chmod: cannot access ‘install.py’: No such file or directory
[root@cyberpanel ~]# python install.py [198.199.90.154]
You need to install 2 important things before you install CyberPanel
yum install wget nano -y
And then run the install commands. wget will help you download things to your VPS and nano will help you edit files (which might not be necessary now, but you may need it later)
After installing these two programs, you can re-run install commands.
