Hey Everyone,
I am setting up a webserver that will primarily be hosting my client’s WordPress websites. I am accustomed to the WHM / CPANEL experience - and used to host on managed VPS so I didn’t have to worry about a lot. Getting into rolling my own servers.
I already went through a setup process on Google Compute Engine with CPANEL, CloudLinux, Litespeed, Kernel Care, and Imunify360. Seemed like a really simple way to just not worry about anything (but kind of expensive). The problem is I ran into a lot of issues just following their instructions, and have already had multiple license lockout issues with CPANEL… so I got looking at alternatives.
I am very interested in cyberpanel now. The setup process was very easy, and it appears to be much less resource-intensive on its own.
It appears that Cyberpanel does everything I need it to. The following are my questions, and I’m wondering if anyone can help addressing them.
I was using cloud linux, and that came with a few benefits I’m looking for alternatives for.
Kernel Care Alternative: Is there a CentOS 7 ability for automatic security / kernel updates that avoid restarting the server?
CageFS Alternative: Does Cyberpanel already handle what CageFS provided, essentially with the “containerization” feature? https://cyberpanel.net/docs/1-introduction-to-containerization-website-limits/
PHP Versions: it looks like cyberpanel supports site selecting a custom php version? Is this just lacking the retroactive PHP fixes that CloudLinux supplies?
Imunify360 Alternatives
What does a typical security setup look like for you guys? Any firewall / ddos / virus and malware scanner suggestions?
