Nobody helps me with this problem, it won’t let me send email, I get this error
Help Help
Help Help
Hello
Login with SSH and check
telnet yourmainserver.com 25
and check Mail Server SSL
using: //email/testTo:
And then check the
systemctl status postfix
systemctl status dovecot
Check Snappy Mail Admin
I can't send mail - #6 by josephgodwinke.
Also try login with IMAP or POP3 to Outlook or any other mail clients. Use the proper credentials and try sending email from these external clients.
Nothing works for me at all
If you have tried this, you should post the results screenshot then someone can understand and help you. Otherwise who will be interested.
can you please send email at [email protected]
