Hi folks,
This is my first post, so I want to start giving you a lot of credits for your great product! I really love it! Everything works right out of the box!
But… I ran into a small problem with N8N installed as a Docker app.
When I test or execute nodes in a workflow, nothing seems to happen (visually) in the UI. No errors, no Success message, nothing. I’ve been digging a lot on the forums and couldn’t find a fix. After a while I found out that it has something to do with ‘websocket’ issues.
I was able to fix it by adding a proxy item to the url containing the n8n instance in the litespeed webpanel under “Web Socket Proxy” like so:
URI: /
Address: 127.0.0.1:11000
This solved all of my issues I was running into ![]()
I think this would be something to include in the next update
Keep up the good work team!
