Hi
I have ubuntu 20.04 and installed the latest cyberpanel
now the ftp wont start and when I start it manully from controlpanel , I’m not able to login with ftp tools like winscp or filezila
this is my log file from cyberpanel
Feb 16 14:09:33 localhost postfix/bounce[5297]: 9B12766522C: sender non-delivery notification: A611866522E
Feb 16 14:09:33 localhost postfix/qmgr[1933]: 9B12766522C: removed
Feb 16 14:09:33 localhost postfix/qmgr[1933]: A90E566522F: from=<[email protected]>, size=65416, nrcpt=1 (queue active)
Feb 16 14:09:33 localhost postfix/local[5296]: A611866522E: to=<[email protected]>, relay=local, delay=0.04, delays=0.02/0/0/0.02, dsn=5.2.2, status=bounced (cannot update mailbox /var/mail/root for user root. error writing message: File too large)
Feb 16 14:09:33 localhost postfix/qmgr[1933]: A611866522E: removed
Feb 16 14:09:33 localhost postfix/local[5294]: A90E566522F: to=<[email protected]>, orig_to=<root>, relay=local, delay=0.06, delays=0.04/0/0/0.02, dsn=5.2.2, status=bounced (cannot update mailbox /var/mail/root for user root. error writing message: File too large)
Feb 16 14:09:33 localhost postfix/cleanup[5291]: B3D5866522C: message-id=<20230216103933.B3D5866522C@localhost>
Feb 16 14:09:33 localhost postfix/qmgr[1933]: B3D5866522C: from=<>, size=2245, nrcpt=1 (queue active)
Feb 16 14:09:33 localhost postfix/bounce[5297]: A90E566522F: sender non-delivery notification: B3D5866522C
Feb 16 14:09:33 localhost postfix/qmgr[1933]: A90E566522F: removed
Feb 16 14:09:33 localhost postfix/local[5296]: B3D5866522C: to=<[email protected]>, relay=local, delay=0.03, delays=0.01/0/0/0.02, dsn=5.2.2, status=bounced (cannot update mailbox /var/mail/root for user root. error writing message: File too large)
Feb 16 14:09:33 localhost postfix/qmgr[1933]: B3D5866522C: removed
Feb 16 14:09:34 localhost postfix/smtpd[5654]: connect from unknown[91.224.92.22]
Feb 16 14:09:37 localhost postfix/smtpd[5654]: warning: unknown[91.224.92.22]: SASL PLAIN authentication failed:
Feb 16 14:09:37 localhost kernel: [ 3221.483325] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=182.176.178.204 DST=<IP Address> LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=22935 DF PROTO=TCP SPT=60495 DPT=1433 WINDOW=8192 RES=0x00 SYN URGP=0
Feb 16 14:09:37 localhost postfix/smtpd[5654]: disconnect from unknown[91.224.92.22] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 16 14:09:54 localhost postfix/smtpd[4743]: connect from unknown[141.98.11.14]
Feb 16 14:09:57 localhost postfix/smtpd[4743]: warning: unknown[141.98.11.14]: SASL PLAIN authentication failed:
Feb 16 14:09:57 localhost postfix/smtpd[4743]: disconnect from unknown[141.98.11.14] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 16 14:10:01 localhost CRON[5692]: (root) CMD (/usr/sbin/imunify-notifier -update-cron)
Feb 16 14:10:01 localhost CRON[5693]: (root) CMD ( imunify360-agent malware on-demand check-detached > /dev/null 2>&1 || :)
Feb 16 14:10:15 localhost postfix/smtpd[5654]: connect from unknown[141.98.11.111]
Feb 16 14:10:18 localhost postfix/smtpd[5654]: warning: unknown[141.98.11.111]: SASL PLAIN authentication failed:
Feb 16 14:10:18 localhost postfix/smtpd[5654]: disconnect from unknown[141.98.11.111] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 16 14:10:29 localhost kernel: [ 3274.051193] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=162.142.125.136 DST=<IP Address> LEN=44 TOS=0x00 PREC=0x00 TTL=36 ID=136 PROTO=TCP SPT=49900 DPT=8080 WINDOW=1024 RES=0x00 SYN URGP=0
Feb 16 14:10:33 localhost postfix/pickup[4292]: B83F066668C: uid=0 from=<root>
Feb 16 14:10:33 localhost postfix/cleanup[5300]: B83F066668C: message-id=<20230216104033.B83F066668C@localhost>
Feb 16 14:10:33 localhost postfix/qmgr[1933]: B83F066668C: from=<[email protected]>, size=66153, nrcpt=1 (queue active)
Feb 16 14:10:33 localhost postfix/local[5294]: B83F066668C: to=<[email protected]>, orig_to=<root>, relay=local, delay=0.06, delays=0.04/0/0/0.02, dsn=5.2.2, status=bounced (cannot update mailbox /var/mail/root for user root. error writing message: File too large)
Feb 16 14:10:33 localhost postfix/cleanup[5291]: C3F1366668D: message-id=<20230216104033.C3F1366668D@localhost>
Feb 16 14:10:33 localhost postfix/bounce[5297]: B83F066668C: sender non-delivery notification: C3F1366668D
Feb 16 14:10:33 localhost postfix/qmgr[1933]: C3F1366668D: from=<>, size=2245, nrcpt=1 (queue active)
Feb 16 14:10:33 localhost postfix/qmgr[1933]: B83F066668C: removed
Feb 16 14:10:33 localhost postfix/local[5296]: C3F1366668D: to=<[email protected]>, relay=local, delay=0.04, delays=0.01/0/0/0.02, dsn=5.2.2, status=bounced (cannot update mailbox /var/mail/root for user root. error writing message: File too large)
Feb 16 14:10:33 localhost postfix/qmgr[1933]: C3F1366668D: removed
Feb 16 14:10:34 localhost kernel: [ 3278.452288] Firewall: *UDP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=151.106.38.158 DST=<IP Address> LEN=673 TOS=0x00 PREC=0x00 TTL=113 ID=18318 PROTO=UDP SPT=27697 DPT=6935 LEN=653
Feb 16 14:10:35 localhost kernel: [ 3279.103618] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=178.62.81.147 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=237 ID=32615 PROTO=TCP SPT=55736 DPT=18892 WINDOW=1024 RES=0x00 SYN URGP=0
Feb 16 14:10:38 localhost kernel: [ 3282.808794] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=89.248.165.104 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=20960 PROTO=TCP SPT=55887 DPT=2020 WINDOW=1024 RES=0x00 SYN URGP=0
Feb 16 14:10:39 localhost kernel: [ 3283.561758] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=94.182.1.170 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=16919 DF PROTO=TCP SPT=50275 DPT=8291 WINDOW=14600 RES=0x00 SYN URGP=0
Feb 16 14:10:41 localhost kernel: [ 3285.947725] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=192.241.216.11 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=236 ID=54321 PROTO=TCP SPT=46449 DPT=11211 WINDOW=65535 RES=0x00 SYN URGP=0
Feb 16 14:10:53 localhost kernel: [ 3297.913351] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=165.232.73.26 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=7163 PROTO=TCP SPT=59968 DPT=23397 WINDOW=1024 RES=0x00 SYN URGP=0
Feb 16 14:10:54 localhost postfix/smtpd[4743]: connect from unknown[141.98.10.26]
Feb 16 14:10:56 localhost postfix/smtpd[4743]: warning: unknown[141.98.10.26]: SASL PLAIN authentication failed:
Feb 16 14:10:56 localhost postfix/smtpd[4743]: disconnect from unknown[141.98.10.26] ehlo=1 auth=0/1 quit=1 commands=2/3
Feb 16 14:11:01 localhost CRON[5750]: (root) CMD (/usr/sbin/imunify-notifier -update-cron)
Feb 16 14:11:06 localhost kernel: [ 3310.802261] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=45.134.144.211 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=39146 PROTO=TCP SPT=40325 DPT=5060 WINDOW=1024 RES=0x00 SYN URGP=0
Feb 16 14:11:10 localhost kernel: [ 3314.840845] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=94.182.212.46 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=24733 DF PROTO=TCP SPT=52764 DPT=8291 WINDOW=14600 RES=0x00 SYN URGP=0
Feb 16 14:11:11 localhost kernel: [ 3315.292085] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=118.193.72.69 DST=<IP Address> LEN=44 TOS=0x00 PREC=0x00 TTL=45 ID=0 DF PROTO=TCP SPT=48679 DPT=6050 WINDOW=1024 RES=0x00 SYN URGP=0
Feb 16 14:11:20 localhost kernel: [ 3324.105286] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=154.89.5.92 DST=<IP Address> LEN=44 TOS=0x00 PREC=0x00 TTL=240 ID=21973 PROTO=TCP SPT=58914 DPT=2077 WINDOW=1024 RES=0x00 SYN URGP=0
Feb 16 14:11:20 localhost kernel: [ 3324.550991] Firewall: *TCP_IN Blocked* IN=ens160 OUT= MAC=00:0c:29:00:33:08:f0:f7:55:7d:d5:80:08:00 SRC=104.131.144.12 DST=<IP Address> LEN=40 TOS=0x00 PREC=0x00 TTL=236 ID=54321 PROTO=TCP SPT=44896 DPT=4118 WINDOW=65535 RES=0x00 SYN URGP=0
and this file is empty /var/log/messages
