Hello, dear all,
I have been using CyberPanel for 1 year, and before 3 days, my CyberPanel installed VPS time to time going offline. I checked the error log but could not find an error. Can someone help fix this?
Thank you
Hello, dear all,
Thank you
what do you see if you run htop command ?
Right now it seems OK. Keep monitoring to see which server process is taking lots of your CPU and then investigate from there.
