Hello, my server is not opening 157.173.124.86, port=8090 , all i get is unable to connect, please help
Read this:
Hi, thanks but i did not get this email. or how did you get this.
SSH connection not working and being rejected
Go to :8090/firewall/secureSSH
click Save Changes then you can login SSH again
Read more here:
all the files are encrypted
I somehow managed to escape the troubles that others are having (upgrading to v2.3.7), but I’m unable to log in via SSH.
- after CyberPanel was Upgraded, ssh eventually timed out and logged me out. i haven’t been able to log back in via ssh since… and it simply “times out” on me
- my password for :8090 isn’t working for me, so i cant update SSH info via panel interface either
any suggestions?
Reset your admin pass through SSH
If you can’t SSH then login directly to your server through iDRAC or other systems that your hosting company might provide. If not then I don’t know how you will gain ssh access back to the system.
Also 2.3.7 is bad, 2.3.8 is the version that has the fix.
thanks for the reply. …then v2.3.7 would explain why i’m having these problems.
i’m trying to log in via remote IPMI, but have been unsuccessful. i just had a realization that SSH has been stopped… so that’d probably effect my ability to login remotely via ssh, yes/no?
