My cron entries are not working either I add using crontab -e or vi /etc/crontab the entry is as follows
- postsuper -d ALL
I also restarted cron after adding still doesn’t work
Any Suggestion
Any Suggestion
Have you tried to run this command manually on the terminal?
what is the output?
