i am using ubuntu 20.04 with cyber panel openlitespeed and i am getting lots of following error on LiteSpeed web admin console
[Module:Cache] createEntry failed, may due to no permission to write file or file is updating.
i am getting lots of this error.
i tried to run this command after to check if all is ok
rm -rf /usr/local/lsws/cachedata/*
ls -l /usr/local/lsws | grep cachedata
after using this command i found following data
root@ssdnodes:~# ls -l /usr/local/lsws | grep cachedata
drwxr-xr-x 3 nobody nogroup 4096 Jun 3 21:40 cachedata
it should be nobody:nobody right???
how can i solve this?
