ModSecurity on CyberPanel Problem Stripe hooks
Hi Guys, My website use to work normally after I followed the instruction to enable and install ModSecurity.
if any of my customers want to pay using stripe after payment when he clicks on return to the merchant they will have ‘‘403 Forbbiden error’’ and their balance will not be updated.
And in the same time, I can’t deactivate the security. How can I fix this problem ??
The URL like this would be blocked by the ModSecurity:
https://example.com/add_funds/stripe3ds/complete?session_id=cs_live_a14EHSM5SIWbb5DhvF&paymentOption=stripe3ds&orderId=ORDS165271
Please help & Thank you
See from logs which rule block that and disable it.
