I’m trying to issue mailserver SSL for mail.domain.com at CyberPanel. After clicking the Issue SSL button, it says “SSL Issued, your mail server now uses Lets Encrypt!”.
After that, I try to link the email through Gmail and enter the below details:
and I got this error:
Authentication failed. Please check your username/password.
Server returned error: “TLS Negotiation failed, the certificate doesn’t match the host., code: 0”
However, I can proceed to the next step if I choose port 25 unsecured connection.
I have checked at the server log and it says self signed SSL issued for mail.domain.com
[08.16.2021_08-17-29] Trying to obtain SSL for: mail.domain.com and: www.mail.domain.com
[08.16.2021_08-17-29] /root/.acme.sh/acme.sh --issue -d mail.domain.com -d www.mail.domain.com --cert-file /etc/letsencrypt/live/mail.domain.com/cert.pem --key-file /etc/letsencrypt/live/mail.domain.com/privkey.pem --fullchain-file /etc/letsencrypt/live/mail.domain.com/fullchain.pem -w /home/mail.domain.com/public_html --server letsencrypt --force
[08.16.2021_08-17-32] Failed to obtain SSL for: mail.domain.com and: www.mail.domain.com
[08.16.2021_08-17-32] Trying to obtain SSL for: mail.domain
[08.16.2021_08-17-36] Failed to obtain SSL, issuing self-signed SSL for: mail.domain.com
[08.16.2021_08-17-37] Connection unexpectedly closed
[08.16.2021_08-17-37] Websites matching query does not exist. [installSSLForDomain:72]
[08.16.2021_08-17-37] Self signed SSL issued for mail.domain.com.
I tried the MailServer SSL issue command on the main domain (the one cyberpanel is hosted on) and it worked fine.
Then I tried to use the same command for another domain hosted on the server and it worked, however this caused the main domain certificate to stop working afterwards.
Then I noticed that everytime I tried to use the issue MailServer SSL command for another domain hosted on the server it somehow overrides the MailServer SSL Certificates, and it becomes the only one covered by it, while cancelling all the rest.
So in my case as a workaround, I re-issued an SSL certificate for the main domain (the one CyberPanel is hosted on) and then used it as the host when setting up the SMTP/POP3 connectors in Gmail for the other domains also hosted on the server and it successfully connected through SSL.
Of course this is not a permanent solution, as it requires that all clients on the server should be notifed to use this host instead of their own. But at least the mail server works until we find a proper solution. I hope this helps someone.
Here’s an example to make things a bit simpler:
Let’s say Cyberpanel is hosted on main-domain.com and I also host the another-domain.com on the same server and both have an “info” email account this is how I would set them up using SSL in Gmail:
If so, click ‘Fix Now’ and then you can use that specific domain as hostname in your mail client, don’t issue mailserver ssl again and again, do it only once for rdns domain.
Sorry for my late reply…
No that error dialog is not showing up in the specific domain name I’m facing the issue with.
I still get the “SSL error: Leaf certificate is self-signed” when trying to add that email account to my gmail, using the email’s domain as a host.
I don’t face the same issue with other hosted domains though. There must be something I’ve done wrong with this one’s configuration.
EDIT1: I’ve just noticed that I have not created mail.domain.ext subdomain for this domain name while I have created that for the rest. Could this be the reason the SSL fails?
EDIT2: I’ve added a new domain to my server, created along with it its mail subdomain too.
Issued certificates to both the main domain and its mail subdomain.
Then successfully added the email account to gmail using POP3, however when trying to set up SMTP for outgoing email I get “TLS Negotiation failed, the certificate doesn’t match the host., code: 0” using either 587-TLS or 465-SSL options.
EDIT3: The new domain issue was actually solved by executing these commands through SSH:
