Just got up to expired mailserver SSL and hostname SSL doesn’t seem to auto renew either.
Can someone confirm if Cyberpanel should auto renew SSL via cron for the mailserver/hostname and if so, what is the crontab confguration etc?
Cyberpanel 1.8.9 with LS Enterprise on CentOS
Many thanks
pb007
2
I have the same issue with HOSTNAME SSL not auto renewing. I upgraded from old versions, and fixed it for each domain using the instructions in How to set up Auto SSL Renew on CyberPanel! - Blog Posts - CyberPanel Community , want to know if there are similar instructions for hostname ssl auto renew?
